2012 Brutale 1090 Dash - MVAgusta.net
post #1 of 4 (permalink) Old 03-11-2018, 08:39 PM Thread Starter
I have a 2012 Brutale 1090 with the dash showing an "ENG Fault Fan" message even though both fans work. Also the dash wont turn off even with the ignition turned off. Any ideas?
PBMV4 is offline
post #2 of 4 (permalink) Old 03-12-2018, 02:26 AM
Without delving into the wiring diagram (available here: Team Double 3 Racing | MV Agusta), I'd start by removing the dash fairing, then removing the multi-pin plug from the back of the dash. Clean the connections with contact cleaner, use a bit of electrical grease, then reconnect.
post #3 of 4 (permalink) Old 03-14-2018, 06:31 PM Thread Starter
Thanks but it didnt work. I had to recharge the battery as the dash and whatever else being on caused it to drain. I guess its a trip to GP to get it sorted out.
PBMV4 is offline
post #4 of 4 (permalink) Old 03-15-2018, 08:49 AM
Download the manuals!
@ PBMV4: The manuals (available here: Team Double 3 Racing | MV Agusta) show the troubleshooting for the fan circuit.
Name:  B4 Cooling Fan Trouble Shooting.jpg
If that doesn't cure the problem, then test the temperature switch.
Save yourself the trouble of going to the dealer.
