Disable o2 sensor with resistance - MVAgusta.net
post #1 of 15 (permalink) Old 02-28-2018, 06:50 AM Thread Starter
Hello every body. I would like to disable my o2 sensor on my 1090rr 2011, because it not turn round under 4000rpm
Does someone have already try this. And wich value of resistance i need to use? For the warming circuit and the returning value?
1090RR 2011
ecosmeri is offline
post #2 of 15 (permalink) Old 02-28-2018, 06:57 AM
The problem here is the ECU is looking for a constantly varying voltage indicating the 02 sensor is functioning. If it sees a constant value it will create a fault code and go to a fail safe mode.
You will need either a reflash to turn off the 02 sensor function, or an o2 sensor emulator. A fixed resistance won't work.
post #3 of 15 (permalink) Old 02-28-2018, 07:27 AM
The option is to have your ECU tuned to not look at the O2 sensor. There are a few places that do this when an exhaust system is installed. FWIW, I thought the O2 sensor is on in effect at LOW rpm.
post #4 of 15 (permalink) Old 02-28-2018, 12:22 PM Thread Starter
Ok thanks for your answer, are you sure about that a constant value with generate a fault code?
A mv agusta seller/reparator told me that a 20Mohm will be usefull for that, but it look really a big resistant for that.
ecosmeri is offline
post #5 of 15 (permalink) Old 02-28-2018, 12:46 PM
Look into the manual for the testing of the O2 sensor. That should give you the ohm readings.
post #6 of 15 (permalink) Old 02-28-2018, 02:13 PM Thread Starter
I have already look. They talk only about mVolts between 0 and 1000. If i knes the ampere (A) i could calculate it
Thanks for your help
ecosmeri is offline
post #7 of 15 (permalink) Old 02-28-2018, 02:39 PM
The narrow band o2 sensor is used by the ECM at less than 1/4 throttle and under about 4000 rpm. It is controlling fuel mixture at idle and low throttle openings only. You will get a fault code if the ECM doesn't see it working.
Some bikes will accept a fixed value resistance. Mostly pre-Euro3 Japanese models. MV and Ducati (and I think maybe BMW) ECMs are looking for varying voltage signals to confirm sensor function is normal. Same thing on cars.
I don't think you can use the DynoJet PowerCommander o2 Eliminator (a fixed resistance) on your bike. The "Tuner Car" guys use an Emulator that generates a fixed signal for lamda that tricks their ECMs....look for one of those.
Or get your ECM reflashed to ignore lamda.
post #8 of 15 (permalink) Old 03-01-2018, 03:08 AM Thread Starter
Is it possible to flash the ecu in my own? I have all the software guzzidiag and ecu reading / writing. But i never do that...
1090RR 2011
ecosmeri is offline
post #9 of 15 (permalink) Old 03-01-2018, 06:04 AM
revhead1957's Avatar
Time to find another seller/reparator. If that is their level of knowledge, I would not be using them to provide any type of mechanical service on my bike.
revhead1957 is online now
post #10 of 15 (permalink) Old 03-01-2018, 08:20 AM
While it is possible, if you have the right software, hardware, and knowledge of what you are doing, all of that is expensive.
There is a guy near me who can do what you need for under $500.00.
Here's the problem, and my constant plea: I have no idea what continent you are on, or planet for that matter. If you would kindly flesh out your profile a bit...I don't mean down to the color of your shingles, but at least a country would be nice. That way I could directo you to Rob, or Doug, or Max, or The-Man-in-the-Moon if you are closer.
Also, is that still the 5SM Magneti Marelli ECU?
Teeps and Teeps like this.
