Cam chain tensioner very bad - MVAgusta.net
LinkBack Thread Tools
Old 02-25-2018, 08:21 PM Thread Starter
MyzTied's Avatar
Well I had the dreaded cam chain rattle. So I embarked on changing it because it had the original in there. Here's a couple pictures of what I found when I pulled the old one out
F4 1000 R
We need more cow bell
MyzTied is offline
Old 02-26-2018, 05:06 AM
revhead1957's Avatar
Oh dear. Hope you found the other pieces in the sump.
revhead1957 is offline
Old 02-26-2018, 05:56 AM
AusMV312's Avatar
Yike!!
Lucky you got to it before something major happened. I'm assuming you've researched this website and read the outcomes of this design fault and the things you can do to stop it from happening again. If not, there's a shipload available.
Current 2008 F4 312R
Track Bike
Past '93 Ducati 900 SS
'82 Suzuki GSX 1100 SZ Katana
? Suzuki GS 850 G Shaft Drive
? Honda XL 500
'82 Suzuki GSX 750 SZ Katana
'76 Honda CB 750 Four K6
In my Youth Suzuki RM 80 C
Yamaha YZ 80 C
AusMV312 is offline
Old 02-26-2018, 06:43 AM
Yep...that's how they break. Hence the recall years ago and improved part. Good news is the missing bit of aluminum has a straight drop to the bottom of the sump.
Old 02-26-2018, 09:48 AM Thread Starter
MyzTied's Avatar
Well I haven't changed the oil yet, so I kind of hope to find the pieces then then.
Doing the research on the tensioner on this web site, the difference between manual and the automatic besides the obvious, price is big thing. I just wanted to pass a long that I found the auto tensioner at Motosport.com 180.00. It's a Husqvarna part. PT# 8000A5199.
F4 1000 R
MyzTied is offline
Old 02-26-2018, 12:43 PM
gotfolk's Avatar
IF its not in the interchangeable parts list this should be added to it.
gotfolk is offline
Old 02-26-2018, 01:31 PM
nigelrb's Avatar
Oh. I have a F4 1000R, but no noises. I gather this is a 'regular' problem. I'd best check around for what to be aware of. Anyone offer a clue as to usual mileage to expect this? Thanks.
Edited to say: I have scanned through technical issues (F4) and 'Hand on' threads, but can't immediately locate substance that might assist me be prepared for chain problem. I may well be over-cautious, but might a 'mod' have a link at hand they could share?
2007 MV F4 1000R
Last edited by nigelrb; 02-26-2018 at 02:02 PM. Reason: Additional request for link
nigelrb is online now
Old 02-26-2018, 02:37 PM
There are lots of threads about this subject. Unfortunately most of the pictures have gone since photo bucket is no longer free to use.
Several vital points:
The updated tensioner is black on the outside part that sticks out the front of the motor.. If you have a silver one it is the older version that is prone to failure.
Do the change as per the workshop manual. There is no shortcut. If you do take a shortcut, it is probable that you will upset the valve timing.
The new tensioner when fitted into older motors requires grinding a slight vertical chamfer on the inside edges to allow it to fully seat in. Easily seen when you put the new and the old tensioner side by side.
The Following User Says Thank You to revhead1957 For This Useful Post:
Old 02-26-2018, 03:27 PM
@nielrb:
http://www.mvagusta.net/forum/20-mai...-question.html
http://www.mvagusta.net/forum/20-mai...tensioner.html
Old 02-27-2018, 07:12 PM
Changing CCT....
Remove the valve cover
Put the motor on TDC with the phonic wheel
Loosen the end cam bearing block bolts enough to insert some strips of paper, retighten the bolts
Safety wire the cam chain to both sprockets
That way it can't jump time
Now change the CCT......don't forget the paper
