2005 F4 running on 2 cylinders - MVAgusta.net
  • 2 Post By fasduc
post #1 of 9 (permalink) Old 02-08-2018, 02:45 PM Thread Starter
fasduc's Avatar
Hey guys, I searched the forum for some ideas and have not found any for my issue. I started the bike in the garage and it fired up fine on all 4 cylinders, shut it off and rolled it out to the driveway to ride. Started it and it was really hard to start with what sounded like a weak battery and running on 2 cylinders.
I thought ok it must be the weak battery causing the problem. I installed a new battery and it still ran on 2 cylinders. I then installed a new EBS relay I had on hand thinking that would fix it, wrong.
It appears to be only running on cylinders 2 and 3, 1 and 4 are dead. Please send your thoughts on what might be the issue.
Thanks,
Chris
fasduc is offline
post #2 of 9 (permalink) Old 02-08-2018, 04:31 PM
Fouled plugs ??? Always a first check, since you have to take the tank off to get at other items to test anyway.
Confirm spark, confirm injector spray.
Probably something simple.....just not simple to find necessarily.
post #3 of 9 (permalink) Old 02-08-2018, 05:01 PM
I think this is the third bike this week reporting a similar issue.
post #4 of 9 (permalink) Old 02-08-2018, 05:45 PM Thread Starter
fasduc's Avatar
Thanks guys! I'll check and report back
fasduc is offline
post #5 of 9 (permalink) Old 02-08-2018, 05:45 PM
AgustaRod's Avatar
I would check plugs for fouling then swap the coil for 1&4 with 2&3 if the misfre moves to the other cylinders you have a coil issue or wiring issue.
I would expect the coil to have a live feed at each coil and a triggered earth from the ECU .
Check the wiring loom at the right side of the bike just a little above the fuse box they can cause issues.
Good hunting.
Keep your MV in good repair: motorcycle boots are not designed for walking.
AgustaRod is offline
post #6 of 9 (permalink) Old 02-09-2018, 02:40 AM
Probably not the case as you have 1&4 out but it's woth checking the rubber caps are seated on the throttle body balance pipes on either side...
merc07 is offline
post #7 of 9 (permalink) Old 02-09-2018, 03:55 AM
Glenno's Avatar
Glenno is offline
post #8 of 9 (permalink) Old 02-11-2018, 07:44 PM Thread Starter
fasduc's Avatar
Hey guys, I lucked out, it was only fouled plugs on 1 and 4. Replaced all plugs with new ones. It is back up and running! Thanks for the tips!
fasduc is offline
post #9 of 9 (permalink) Old 02-12-2018, 10:01 AM
Thanks for reporting back!
