990R Coil, Plug or ECU Issue ? - MVAgusta.net
post #1 of 21 (permalink) Old 02-04-2018, 12:41 AM Thread Starter
cruiser's Avatar
Unhappy 990R Coil, Plug or ECU Issue ?
Hello family - calling on your experience please.
Three days ago the Brutale started running on 3 cylinders out of the blue... The bike was running rough until I hit about 4000rpm and then it would fire up on all 4 pots. It had been running perfectly fine up until then. However, the day prior had been a pretty damp (not torrential) ride to/from work. As I was on my way to the office I continued to limp along believing it might just a small blip and would clear itself. (the round trip is 60km). The ride home was reasonably rough as well.
Day 2 The_Castle was up in Auckland so we decided to get into diagnostic mode and commenced testing. In our testing mode I quickly encountered a "Coil 2" error on the dash. We removed all the spark plugs and checked the condition of each - we noted that #2 had some weird correction but nothing that looked really out of place. We tested each spark using Coil 1 and confirmed spark on each plug (not we didn't start the bike, we simply confirmed that spark was occurring on each plug via Coil 1. We also swapped Coil 1 and Coil 2 over. Still had a Coil 2 error.
Day 3 I've just replaced all spark plugs - still running on 3 cylinders and Coil 2 error still exists. I then Pull Coil 1 and encountered a Coil 1 and Coil 2 error. I then re-seated Coil 1 and error disappeared however Coil 2 error remained. I then swapped Coil 2 and 1 (yes, the swap included the both the Coil and the plugs below the fuel rail. Restarted bike and Coil 2 error sill occurred. This clearly tells me it's not the actual Coil ...or did I miss something?
I then tested the heat on each of the header pipes and pot 2 header was definitely cooler (not cold) than the others. I have checked the fuses and nothing appears awry.
So in summary it feels like command is inconsistently reaching Coil 2 - without the diagnostic tools I think I've gone as far as I can?
Thoughts please gents? (I don't have any electrical testing gear or should I get an amp meter and see if the female plug to Coil 2 is getting something) ?
...Hope that explains what the hell I've been up too.
Tim
Tim
Current
MV Agusta Brutale 1090RR
Past
MV Agusta Brutale 750s
cruiser is offline
post #2 of 21 (permalink) Old 02-04-2018, 04:45 AM
revhead1957's Avatar
2010+ bikes seem to have a habit of eating beru coils.
I presume you have checked compression on no.2?
Change plugs first, being the cheapest option.
revhead1957 is offline
post #3 of 21 (permalink) Old 02-04-2018, 04:49 AM
Deano's Avatar
Been here a few times. I say coil(s) especially as you've changed all the plugs.
Deano
Deano is offline
post #4 of 21 (permalink) Old 02-04-2018, 09:35 AM
With the error not following the coil position, I would start checking the lead in to coil #2.
Glenno and Glenno like this.
post #5 of 21 (permalink) Old 02-04-2018, 03:00 PM Thread Starter
cruiser's Avatar
Thanks Chuck, I feel that it is the next logical step...tracing the lead Uhggg...
cheers
Tim
Current
Past
cruiser is offline
post #6 of 21 (permalink) Old 02-04-2018, 05:59 PM
I'm with Chuck on this one, try some dielectric grease on all the connections
post #7 of 21 (permalink) Old 02-04-2018, 07:09 PM Thread Starter
cruiser's Avatar
Thanks Noel.
Tim
Current
Past
cruiser is offline
post #8 of 21 (permalink) Old 02-04-2018, 07:27 PM
Tim;
Diagnostics has detected a bad connection..... you know the plugs and coils are OK
That leaves the coil wire and connectors for #2
Bet water got in
post #9 of 21 (permalink) Old 02-04-2018, 10:30 PM Thread Starter
cruiser's Avatar
Tim;
Bet water got in
I think you're right mate - so is this a compressed air and dielectric grease cleaning approach ?
Tim
Current
Past
cruiser is offline
post #10 of 21 (permalink) Old 02-04-2018, 11:34 PM
Tim;
I think you'll do better with an electric hair dryer and dielectric grease...
High pressure air could drive the moisture deeper, not what you want
