910 2008 not firing no electricity to injectors?? - MVAgusta.net
 2Likes
  • 4 Post By esq'z me
post #1 of 10 (permalink) Old 02-03-2018, 08:21 AM Thread Starter
So my bike head light low beam was not working, I did track it to SPU as it pin was not making contact with the plug.
Problem fixed... well no! Now bike will not start! Starter works. Fuel pumps primes, and there is spark! it will fire if pour fuel directly in the throttle bodies.
Work shop manual say that injectors connect to pin 8 on SPU but this must be wrong in newer type ECU.
It seems injectors are not getting 12v? did took them off and insert multimeter and did not get any voltage when starting the bike or turning the key.
Anybody have any idea what could have failed?
Is there any current wiring diagrams for 2008 bikes?
- Yamaha FZ1N 2007 (sold)
- CFMoto 650NK 2013 (sold)
- CBR1000rr 2008 (sold)
- Aprilia Shiver 750 2008 (sold
- MV Agusta Brutale 910 2008
Wald0 is offline
post #2 of 10 (permalink) Old 02-03-2018, 09:04 AM
The wiring diagrams and the fuel injection troubleshooting guide are in the workshop manuals for you bike available here: Team Double 3 Racing | MV Agusta
post #3 of 10 (permalink) Old 02-03-2018, 09:34 AM
Before you go down that path, I suggest you check that the internal fuel hose from the pump has not popped off.
Very common and well known cause of no start/no fuel delivery.
I'm not the only one this has happened to.
post #4 of 10 (permalink) Old 02-03-2018, 11:22 AM Thread Starter
Have those already.
Wald0 is offline
post #5 of 10 (permalink) Old 02-03-2018, 07:32 PM
Ed;
The OP says the pump cycles
WaldO;
There are 2 trouble shooting guides, one in Section E the other in Section O
post #6 of 10 (permalink) Old 02-03-2018, 11:39 PM Thread Starter
Does anybody have better quality ELECTRICAL DIAGRAM BRUTALE 910 S R (MY 2007)?? the one what is in manuals is so bad quality ::/ can't make any sense about color codes at all as image is too blur..
Wald0 is offline
post #7 of 10 (permalink) Old 02-04-2018, 11:54 AM Thread Starter
UPDATE, All good now! well still no lowbeam, but bike is running. Have no idea why now injectors are getting power and before they was not. Also did swap main starter relay same time so not sure could that been culprit..
Wald0 is offline
post #8 of 10 (permalink) Old 02-04-2018, 07:32 PM
Does your SPU have a blue or black back?
post #9 of 10 (permalink) Old 02-05-2018, 09:00 AM
FWIW, with a disconnected fuel pump discharge hose, the pump will still cycle when the ECU tells it to.
(For the nay-sayers, it has happened to me on my 312R.)
post #10 of 10 (permalink) Old 02-05-2018, 07:00 PM Thread Starter
It has black back.
Wald0 is offline
