Fuel line query - MVAgusta.net
 3Likes
post #1 of 43 (permalink) Old 02-01-2018, 05:37 AM Thread Starter
cus
cus's Avatar
Fuel line query
Put new 3/8 fuel lines on my 1078 brutale and am wondering what the point of the 3/8 lines are when the fittings at the fuel rail are 5/16 and the internal size of the tank quick connects are similar to 5/16 ( couldn’t be arsed measuring them). Just thinking 5/16 lines might have been better for ease of routing.
cus is offline
post #2 of 43 (permalink) Old 02-01-2018, 08:19 AM
airjawed's Avatar
I think flow would be less if the entire line was 5/16. More overall restriction is harder on pump and allows less fuel across.
airjawed is offline
post #3 of 43 (permalink) Old 02-01-2018, 08:21 AM
5/16 is what you should have used, but it can be difficult to insert the barbed end of the connector.
post #4 of 43 (permalink) Old 02-01-2018, 02:43 PM
MVAgusta.net Sponsor
mitchy's Avatar
Mark I used 5/16 on my 1078 and made them 2 inches longer for ease of tank removal next time.The 5/16 hose fits perfect.
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is online now
post #5 of 43 (permalink) Old 02-01-2018, 07:10 PM
Thumbs up wtf???
Wrong.....
The male John Guest fittings on the fuel rail are 0.185" I'D 35% of 5/16"
The pressure regulator keeps line pressure at 3 bar
Extra fuel pressure is bled off back into the tank
post #6 of 43 (permalink) Old 02-01-2018, 08:46 PM
airjawed's Avatar
I'm not talking about when the flow is lower than what is needed. I'm talking about full throttle.
My car has a fuel pressure regulator and does flow back to tank. So it always circulates past the injectors and back to tank. It also adds pressure as the manifold pressure changes.... turbo charged fueling. FPR after injectors. I run higher than stock boost and have a high flow fuel tank, bigger injectors etc. Not stock...stage 3 build.
My F3 800 has injector at the end of the line. Regulator is at tank. I've never seen a FPR after injector on a bike but doesn't mean 1078 doesn't. I don't know.
My point is that a fuel line with a single narrowing flows better than a line that is narrow the entire way when flowing at high volume.
Wrong.....
airjawed is offline
post #7 of 43 (permalink) Old 02-02-2018, 06:48 AM
While there is a pressure drop over length for any hose, and that pressure drop is relative to inside diameter and length of hose, on this system there is excess supply built in by having a return line pressurized to a value higher than necessary for full throttle demands.
You could put a one inch I.D. supply line in and it would not improve flow.
On the single line systems (later bikes >'10) the pressure is maintained at a value that will encompass all demand and have excess supply.
A cautionary tale about making the hoses longer: I did just that on my 312R. I also installed new CPC fittings both male and female. I believe, but I haven't been able to prove it yet, that the hose routing, coupled with the extra length, puts enough pressure on the fittings such that in time they disconnect enough to interrupt fuel flow.
I'll be testing my theory when riding weather returns, but I have been caught out, as has Curtis when he borrowed my 312R at Gapalicious 2017. Disconnecting and reconnecting the lines is all that was needed to restore fuel flow.
post #8 of 43 (permalink) Old 02-02-2018, 06:31 PM
My '03 built Aprilia RSVR's FPR references manifold pressure
All 1st Gen MVs have FPRs on the return line
Haven't dealt with the 2nd Gen POS
How much REAL horsepower is your racecar making?
Here is where you find out what you need
RC Fuel Injection > Technical
From my mentor and friend RC
post #9 of 43 (permalink) Old 02-03-2018, 12:12 AM
airjawed's Avatar
I have a F3 800 POS like many of us half ass MV owners. Clearly I we don't live up to your standards. Thanks for letting us live in your world.
I think having a return line type is nice because fuel is always moving and no chance of vapor locking or heating up. Didn't think that bikes would do a return line since I haven't seen that on any of the newer bikes. But, I haven't worked on that many to really say. Again, I own POS bikes and cars and so do all my friends.
My car is a pretty common Audi B5 S4 Avant stage 3 build. I have not put my car on a dyno but most examples are are at 400 hp/tq to the wheels minimum. I didn't want to go excessive since I never wanted to do a built bottom end and I decided to keep my transmission as is(auto). Its a nice sleeper build daily driver.... 250,000 miles so I think I've kept it a reasonable and safe build. Many cars make more power. There is always someone faster. I'm no exception. But I loved the process of doing it!
I'm not going to respond any more to your posts. This thread was a simple one and I just gave something to think about.
airjawed is offline
post #10 of 43 (permalink) Old 02-03-2018, 04:45 AM
mitchy's Avatar
Hi Chuck,happy new year.Fitting 5/16 fuel line and 2inches longer makes no drop in fuel pressure at all,the motor runs perfect.The fuel pump delivers enough pressure to handle the slight reduction in hose diameter and a measly 2inches in length.We can All do with an extra 2inches.lol.
Bike- F4 1078 312rr
Mobile-0423041326
