Alarm replacement - MVAgusta.net
post #1 of 12 (permalink) Old 01-28-2018, 07:15 AM Thread Starter
Alarm replacement
Ok so my F3 repair is on hold until the parts get here so I turned my attention to the 2011 F4. Installed all the panels, headlight and "new" clutch and then the drama.
When I turn the ignition the alarm goes ballistic. Now I stand there looking at it cause when I got it on auction there was no FOB given to me and Like an @$$ I never really thought about it.
I've just looked for a replacement alarm but the only ones I see are from MV and not the datatool one installed. So I come to the temple of MV knowledge to ask the following -
1.Any idea where to get a replacement datatool alarm (please don't say visit a technician cause the local MV distributor is the only I know of over here)
2.Should I even bother going back to datatool cause I've read some hairy things about them, not sure if true or not.
3.Can I just rip it out and use bubblegum instead?
dav777 is offline
post #2 of 12 (permalink) Old 01-28-2018, 08:04 AM
Based on the issues with Datatool Alarms, I would simply remove it.
post #3 of 12 (permalink) Old 01-28-2018, 10:38 PM Thread Starter
Heres the issue. It's wired to the harness as far as I can see. If I rip it out the bike wont run, hence me looking for a similar one, but there isn't even a model number on the thing.
dav777 is offline
post #4 of 12 (permalink) Old 01-29-2018, 01:38 AM
Bumpkin's Avatar
Removal is your best bet. It's a laborious task but tracing all wires back to the loom and then de-splicing, matching wire colour codes, soldering with heat shrink over.
Alternatively, if you can ID the model download the instructions from the datatool website. You should be able to order spare fobs. I know that datatool alarms have an internal rechargeable battery, if this goes flat, or terminally bad, it will do as you describe with the alarm sounding when you turn on the ignition.
Whilst alarms are a total PIA I've had three datatools on three different bikes. Only the first was troublesome and that was down to a poor instalation,the real bane of most alarm issues IMHO.
My worst experience was with the POS MV alarm that I had fitted to my TVL. Lasted two weeks before dying, dealer removed and refunded.
Bumpkin is offline
post #5 of 12 (permalink) Old 01-30-2018, 11:12 AM Thread Starter
Good lord, that sound's like I could fry something. WIll probably look for a used datatool and cut and splice close to the alarm itself or replace with a different harness,
dav777 is offline
post #6 of 12 (permalink) Old 01-30-2018, 11:37 AM
Bumpkin's Avatar
If it's anything like the datatool I had on my VFR you should be able to unscrew and separate the case and then unplug the harness from the mother board, just plug your harness into the new unit. That's if you find the right model. maybe elicit the help of Datatool themselves?
Chas
Bumpkin is offline
post #7 of 12 (permalink) Old 01-30-2018, 06:53 PM
Farshore's Avatar
The issue with the F4 alarms apart from the usual battery drainage is the location. MV located the datatool alarm under the seat so directly above the exhaust. The only protection is a thin piece of plastic so the alarm cooks over time and immobilises the bike once itís failed. The best option is to remove it but if youíre really tied to it then fit some effective heat shielding underneath it.
The wiring was epoxied into the body of the unit that I had so making swapping it out difficult. If the fobs can be reprogrammed Iíve got a couple spare for you.
09 F4 312 1000
Farshore is offline
post #8 of 12 (permalink) Old 02-05-2018, 01:57 PM Thread Starter
Thanks for the offer but is it possible to programme fob's without the original? I'm noe faced with 3 options
1. Wing it and see how I can remove the alarm by tracing the cables and pray I dont damage anything.
2. buy complete harness and replace
3. Take it to OEM and pray they dont rip me a new one when removing the alarm.
dav777 is offline
post #9 of 12 (permalink) Old 03-10-2018, 08:16 AM Thread Starter
So, after tinkering with the F3 I finally got around to the F4 and did some tracing the cables and removed the f****ing thing. re-attehed the cables and bam she's up and running.
The datatool is laying on the floor but if anyone here is interested in it, you can have it.
dav777 is offline
post #10 of 12 (permalink) Old 03-11-2018, 03:45 AM
colinpp's Avatar
I had an issue with the Datatool 3 alarm on my Aprilia RSV - the alarm would just randomly activate and the only way to stop it was to disconnect the battery. The alarm had been professionaly installed and I was reluctant to have to strip out and make good all the wiring. I looked online and found this solution -
I just removed the circuit board from the alarm bridged the terminals with the two cut off ends of a large gauge paper clip and replaced the alarm cover. Works a treat and wiring etc left untouched.
Colin
___________________
2015 Rivale
2005 Aprilia RSV Factory
colinpp is offline
