2002 F4 750S cutting out - MVAgusta.net
post #1 of 7 (permalink) Old 12-27-2017, 03:13 PM Thread Starter
Hey guys, got a problem with our MV. It'll suddenly cut out while riding, no back fire, no miss, no stutter, it's as if the kill switch has been pushed. The engine cuts out, and the rev counter drops to zero, the speedo and temp stay working. Then it'll cut back in and either run for a bit, or cut out again.
I've had it on a race stand, held it at 6000rpm and shaken, pulled and pushed on the loom, the fuse box and any other wiring I can grab, inclusding side stand cut out and clutch lever cut out, all good, I've cleaned the fuel tank breathers, and there are no kinks in the fuel lines. Any ideas?
Cheers,
Shane
KiwiMV750S is offline
post #2 of 7 (permalink) Old 12-27-2017, 04:20 PM
Tip Over Switch....
post #3 of 7 (permalink) Old 12-27-2017, 04:29 PM
Never mind...it doesn't have one. I'd be checking for loose ground connections. The latch relay could be going bad also...
post #4 of 7 (permalink) Old 12-27-2017, 05:33 PM
bioluminescence's Avatar
side stand switch. flick your side stand a couple times. if it starts normally, thats probably it. they often go bad, I went through 2 that looked perfectly fine, but the right amount of vibration would kill the bike. $20-$40 on eBay... easy fix.
Nighthawk 650 '83 prune/gunk
FZR 600 '93 red/white
F4 750 '03 red/silver
F3 800 '16 ABS red/silver
bioluminescence is offline
post #5 of 7 (permalink) Old 12-27-2017, 08:55 PM Thread Starter
Tested the latch relay, and it's good.
I would have thought if it was the side stand switch it'd put the warning light up on the insturment cluster?
Keep the ideas coming!!
Shane
post #6 of 7 (permalink) Old 12-27-2017, 09:51 PM Thread Starter
More symtoms
Found the Neutral light is not coming on now, fuel pump won't prime until the clutch is pulled in.....thinking maybe gear position sensor is faulty...
Shane
post #7 of 7 (permalink) Old 01-04-2018, 04:38 PM
Shane;
That would be my vote, wait until you see where it is
I made a slotted socket to remove it
Be sure to test the bullet connector for the switch, right rear of motor
Take connector apart, put the bike in neutral, with an Ohm meter check for continuity
to ground on the wire coming from the switch
