Old champion ignition coil replaced BERU ZS378 - MVAgusta.net
post #1 of 5 (permalink) Old 12-21-2017, 11:52 AM Thread Starter
fat
fat's Avatar
Hi all
My 06 Brutale 910R ignition coil has failed, the ECU is 16M, there is no new champion coil available for order, and I've successfully replaced the old champion with the BERU ZS378 (0040104002)same MV parts 8000A6700,Champion connector has three pins, the right is 1 to ECU,middle is 2 to ground,left is 3 to 12Vbat, the BERU ZS378 coil wire connector 1 is red to ECU, the middle 2 is black to ground, the left 3 is yellow to 12Vbat,all connector have mark 1,2,3, I can be sure it is consistent, without change, as long as the connector then correct,
Special Thanks Pittmeister(The fifth picture owner)let me know this news he write and I am order too,
pass the completed picture to me,and Help me find the used BERU ignition coil
If you don't to do both sets of connectors, the part you need is Bosch 1928404227 - 3 Way Bosch Male. It took me too long to find the connector and a source. I purchased mine from DeyTrade in Germany.
The pins I used were Tyco 1-963748-1 - Male Junior Power Timer Tin Plated Terminal 0.50 - 1.00 mm2 and the seals were Tyco 828904-1 - Blue Individual Loose Cable Seal Junior-Power-Timer 0.35 - 1.00 mm2
I translate through Google
fat is offline
post #2 of 5 (permalink) Old 12-21-2017, 11:59 AM
Nice work!
post #3 of 5 (permalink) Old 02-08-2018, 12:28 PM
Cycle Terminal currently has stock of the Bosch connectors for those of us in the US. At the current conversion rate, the price is about the same.
pittmeister is offline
post #4 of 5 (permalink) Old 02-08-2018, 02:30 PM
Maximum Velocity's Avatar
Great and thanks for sharing!
What a beast of a motorcycle!
Maximum Velocity is offline
post #5 of 5 (permalink) Old 06-19-2018, 10:58 AM
Hi guys,
I think one of my champion bobines failed. Is there a way to check this? The bobines are already disassembled.
Thanks!
Pieter88 is offline
