Arrow Thunder 1/4" clearance to tire? - MVAgusta.net
  • 2 Post By Bootworks
post #1 of 9 (permalink) Old 12-15-2017, 10:58 AM Thread Starter
Bootworks's Avatar
I've just installed an Arrow Thunder (and midpipe) on my '06 910S Brutale. Good weight savings. sounds good, looks nice. But the can lives 1/4" away from the rear tire sidewall: Is that a concern, have I installed it wrong?
Bootworks is offline
post #2 of 9 (permalink) Old 12-15-2017, 03:05 PM
Must be incorrectly installed......1 have 1" from the can to the tire
Maybe this picture will help
post #3 of 9 (permalink) Old 12-15-2017, 09:48 PM Thread Starter
Bootworks's Avatar
Thanks Noel. Back to the drawing board!
post #4 of 9 (permalink) Old 12-15-2017, 10:27 PM
Deano's Avatar
Loosen the header clamp bolts a bit, jiggle and bend everything around a bit and when it looks right re-tighten everything. Usually works for me. The Arrow's usually not a problem but the HP Corse is a bugger to get set right.
Deano
Deano is online now
post #5 of 9 (permalink) Old 12-16-2017, 06:46 AM
Sometimes it is as simple as moving a bracket to the other side of the attachment point.
Can you post a picture or two of your setup?
post #6 of 9 (permalink) Old 12-17-2017, 08:13 PM Thread Starter
Bootworks's Avatar
Thanks, fellows. Me thinks I got'er done.
post #7 of 9 (permalink) Old 12-18-2017, 07:08 AM
...and just what was the solution?
post #8 of 9 (permalink) Old 12-19-2017, 08:53 PM Thread Starter
Bootworks's Avatar
Deano
The solution? Well, I loosened the header clamp bolts a bit, I jiggled and bent everything around a bit. Got it to look right and then re-tightened everything. Then I poured myself a very cold beer and said "Thanks!"
post #9 of 9 (permalink) Old 12-20-2017, 04:18 AM
Thanks for that!
