Charging circuit/battery light flickering gremlin on 1st Gen Brutale - MVAgusta.net
 5Likes
  • 4 Post By pittmeister
  • 4 Post By silentservice703
  • 2 Post By esq'z me
post #1 of 5 (permalink) Old 12-03-2017, 08:31 PM Thread Starter
Hi all.
I am currently having an issue with a 2007 Brutale 910R related to the charging circuit. The charging circuit battery dash light will flash rapidly/flicker when the bike is sufficiently hot, ~180F or higher and/or I am traveling at highway speeds, 65+ mph.
This issue affects the overall performance of the bike. When I had a Power Commander attached, if I was sitting at a light long enough with high engine temps, the battery light would start flickering. While pulling pull away, the engine would buck, cut out for a half a second or so before cutting back in, and would do this a few times. While the engine was cut, the charge light would be solid. When I removed Power Commander the cutting out stopped, but the flickering persists.
Cruising on the highway if the light began to flicker, it felt like the revs would be unsteady at the throttle opening. The feeling was very subtle.
The most interesting symptom is that occasionally during a hard pull/high rpms the light would begin flickering before the headlight would turn off and the dash would reset (all dummy lights would come on and the LCD would blank). I don't recall performance being otherwise affected. One time it started to do this at any speed above 60 mph.
I strapped up a volt meter to the terminals and went for a ride today and it all appeared normal. At idle it would generate 14.3 v, above 2,000 a consistent 14.9-15 v, and when stopped with the fans on 13.4 v. I had it flicker at me for a small stint during the ride while at speed but it was still showing around 14.9 v. I wasn't able to replicate the dash reset, I'll need something a bit more svelte than a multimeter rubber banded to my master cylinder.
I am also getting about 2.5 mA in parasitic loss. I checked some of the easier to reach connectors exposed and under the seats and tank to look for signs of resistance. I found one browned connector sleeve by the wires running near the kickstand, but the contacts still appeared normal. I determined 1 mA of loss from the clock, .4 mA from the 4 pin on the starter relay, .1 mA from the 8 or 10 pin connector under the dash cover. Still searching for the last 1 mA.
I am a bit at block now about what to check or do next, any ideas?
SPU has been upgraded
Beru ignition coils with complimentary Bosch connectors. The issue persisted with the original Champion coils.
Battery is about 10 months old
Power Commander disconnected
No other alterations to the wiring harness or electrical system that I know of or can find.
Thanks all!
pittmeister is offline
post #2 of 5 (permalink) Old 12-04-2017, 05:48 AM
I suspect you have diodes in the rectifier portion of the alternator beginning to fail/short. Possible AC current component leaking into the electrical system causing the symptoms. Would also explain high key off current draw.
It's an automotive alternator, easily repairable. Many threads on the subject. Hardest part of the job is getting it off and back on the bike. There's an old thread about that too.
post #3 of 5 (permalink) Old 03-25-2018, 12:15 PM Thread Starter
So I believe that I have finally resolved this issue. After swapping the diodes and regulator out, I still had the same recurrent symptoms. I began to check my connectors and lo and behold, one of the female terminals in the 10 pin plug to the SPU had backed out. Snapped it back in place and haven't had any issues for the last couple of days. Sometimes it's just the simplistic stuff.
post #4 of 5 (permalink) Old 03-25-2018, 01:12 PM
There is a old mechanics phrase that states the whatever problem you are having now is directly related to earlier maintenance performed.
post #5 of 5 (permalink) Old 03-25-2018, 03:09 PM
Bad connections.....the usual cause of most gremlins in modern bikes of all brands. The components themselves are very reliable. Glad you found yours.
theknurl and theknurl like this.
