Running low RPM, receiving jerking motions. - MVAgusta.net
 2Likes
post #1 of 47 (permalink) Old 11-08-2017, 02:19 AM Thread Starter
ManiacDray's Avatar
2013 MV Agusta Brutale 920
Hi all. Having some issues. Idling was fine, but now its jumping VERY little, however pulling away the bike receives a jerking motion. It feels like it wants to cut out, but hasn't luckily.
This has been going on for a week so far and seems to be getting worse. Spark plugs have been changed and coils have been checked (All good). Oil has been changed, but not the oil filter, cant seem to find it.
I honestly have no clue what could be the cause.
ManiacDray is offline
post #2 of 47 (permalink) Old 11-08-2017, 04:27 AM
@ManiacDray: How do you work on your bike without a manual? Go here and scroll down to your manuals and download them for free:
Team Double 3 Racing | MV Agusta
Your oil filter is in the bottom of your engine sump held in by four bolts and a cover plate.
Read through the engine diagnostics. It might be as simple as a TPS reset.
post #3 of 47 (permalink) Old 11-08-2017, 05:20 AM Thread Starter
ManiacDray's Avatar
I have the workshop manual. Unfortunately the link you gave doesnt have the manual for my bike.
The manual says the filter is located behind the coolant guard, but its not. So I did check under the engine for any cover plates that could be hiding the filter. There was absolutely nothing.
TPS would never have gone through my mind, but its definitely worth a try, thanks.
post #4 of 47 (permalink) Old 11-08-2017, 05:44 AM
The 920 is basically the same engine as all the other MV 4 cylinder models. The oil filter is a spin-on type on the front of the engine behind the exhaust headers.
You will need the software and communications cable to reset the TPS if needed.
How many miles do you have? Does it run normally other than low rpm/idle?
post #5 of 47 (permalink) Old 11-08-2017, 06:02 AM Thread Starter
ManiacDray's Avatar
Yes the manual shows that you need to remove exhaust manifold 3 & 4. From there you will see that it is located behind the coolent guard. I could not find anything of the sort plus I checked under the engine for cover plates, nothing.
Well it starts fine, idling is fine as well. Pulling away form 1000 - 3000 rpm it jerks and feels like cutting out. 3000 rpm and above it was running smooth. Now this morning it only runs smooth from 5000 rpm and up.
post #6 of 47 (permalink) Old 11-08-2017, 06:08 AM
Reset TPS is first task. Look at the shop manual for any MV 4 cylinder for the oil filter. It is not under any plate or cover. It is screwed directly onto the front of the engine....just like on a Honda or Suzuki or Yamaha.
post #7 of 47 (permalink) Old 11-08-2017, 06:10 AM
dansoarr's Avatar
Manual
I think this manual covers yours, see page 3 and page 10
dropbox link
https://www.dropbox.com/s/tz2ct2zzie...20ED6.pdf?dl=0
Arron
2015 MV F4, ABS
ECU Mapped with ECUstudio
others
GSXR 1000
GSXR 750
dansoarr is offline
post #8 of 47 (permalink) Old 11-08-2017, 06:22 AM
dropbox link
Thanks...I added that manual my collection !
Although it doesn't "List" the 920, everything should be covered for him. I think the 920 just has different size piston and lower spec suspension/brakes.
post #9 of 47 (permalink) Old 11-08-2017, 06:41 AM Thread Starter
ManiacDray's Avatar
dropbox link
Awesome, thanks. Will take a look once I get home. Bike is booked for diagnostic test and to reset TPS
post #10 of 47 (permalink) Old 11-08-2017, 11:18 AM
Wink Balderdash!
My 1090RR has this filter:
Name:  B4 Oil Filter.jpg
lefin102 and lefin102 like this.
