spark plug opinion - MVAgusta.net
 7Likes
post #1 of 18 (permalink) Old 10-05-2017, 05:27 PM Thread Starter
number2's Avatar
spark plug opinion
I am not used to looking at the condition of spark plugs an wonder if anyone can tell me if this plug looks ok
number2 is offline
post #2 of 18 (permalink) Old 10-05-2017, 06:07 PM
Deano's Avatar
Looks good to me. However if you've gone to the trouble to check them, if it's on your MV, I'd put a new set in. It's a big job to get them out and back in so you might as well change them regardless of the mileage they've done. If I drop one they all get changed.
Deano
minime and minime like this.
Deano is offline
post #3 of 18 (permalink) Old 10-05-2017, 06:15 PM
Color looks good. I would suggest upgrading to NGK Iridium plugs. You will notice a difference.
NicholasF4 and NicholasF4 like this.
post #4 of 18 (permalink) Old 10-05-2017, 08:07 PM Thread Starter
number2's Avatar
It is out of the Bimota
number2 is offline
post #5 of 18 (permalink) Old 10-05-2017, 08:33 PM
R1andrew's Avatar
Any headway on what happened?
R1andrew is offline
post #6 of 18 (permalink) Old 10-06-2017, 11:44 AM Thread Starter
number2's Avatar
must have been a bad connection. I messed with the plug for the coil and injector. Made sure everything was clean and tight and now it is running. Go figure
Al-, Al-, RBx and 1 others like this.
number2 is offline
post #7 of 18 (permalink) Old 10-06-2017, 12:49 PM
RBx
RBx's Avatar
George,
Glad to hear the Bimota got sorted. To me, that plug looks a bit rich, but not bad, could be a symptom of the bike not running properly.
what does the other plug look like? Is that the horizontal or vertical(rear) cylinder?
I just changed mine and the rear was a bit lean compared to the front, which is typical as the rear cylinder has less airflow (on the air cooled bikes of course) and runs hotter. I may need to balance the throttle bodies or adjust the fuel to get the mix equalized on both cylinders.
If she is running better now, I'd throw new plugs in and put a few miles on it. Pull them again and recheck/compare.
Just my 2¢
RBx is offline
post #8 of 18 (permalink) Old 10-06-2017, 05:22 PM Thread Starter
number2's Avatar
well it seems to be running but the stupid light came back on.
number2 is offline
post #9 of 18 (permalink) Old 10-06-2017, 07:21 PM
R1andrew's Avatar
Guess you will just have to give it to me.
R1andrew is offline
post #10 of 18 (permalink) Old 10-06-2017, 07:45 PM
Al-
Al-'s Avatar
I've got a spare microtec M172 we should apply to this thing
Al- is offline
