2010 1090RR battery - MVAgusta.net
  • 2 Post By Donsy
post #1 of 7 (permalink) Old 08-05-2017, 03:18 PM Thread Starter
Delmar's Avatar
2010 1090RR battery
Hello All-
What battery would you recommend for my 2010 1090RR?
I'm using an interstate product, but the bike needs a bit more, also I'm using a battery tender.
TIA
Marco
Delmar is offline
post #2 of 7 (permalink) Old 08-06-2017, 03:01 AM
For a standard battery you could not beat an Yuasa YTZ10-S
revhead1957 and revhead1957 like this.
post #3 of 7 (permalink) Old 08-06-2017, 04:39 AM
eddypro's Avatar
SSB Lithium ,CCA IS ABOUT 290 , brilliant battery
eddypro is offline
post #4 of 7 (permalink) Old 08-07-2017, 06:31 AM Thread Starter
Delmar's Avatar
Thanks Mates-
Delmar is offline
post #5 of 7 (permalink) Old 08-07-2017, 10:00 AM
I'd go with a lithium battery, or Yuasa for a standard battery.
Also, shameless plug: you should really upgrade the wiring http://www.mvagusta.net/forum/23-a/2...brand-new.html
Fat Pat is offline
post #6 of 7 (permalink) Old 08-27-2017, 09:06 AM
Lithium Ion from Amazon
The one I bought is red and black. There are probably many names, but they're probably all the same. It's 1/4 the weight of a lead acid battery and I feel like I'm getting better cranking amps than the lead acid battery did, even when it was new. Started using these 3 years ago on our ATVs. Before then, I was replacing the lead acid batteries in our ATVs every year because they'll sit unused for so long and I'm too lazy to hook up trickle chargers for every toy. I've only had to replace one since, but because I used a fancy desulfating charger and left it hooked up too long. I guess you're not supposed to use those on Lithium Ion batteries.
moocowman is offline
post #7 of 7 (permalink) Old 08-27-2017, 09:23 AM
Just fitted a lithium Shorai to my 2010 Brutale 1090RR, works a treat so far (only been 2 weeks though).
I have lithium magneti marelli in my 2010 F4 which i would continue to use in all my bikes if i could but carpimoto can no longer ship them overseas.
jhollis is offline
