2015 F4 Battery - How to charge? - MVAgusta.net
post #1 of 5 (permalink) Old 07-18-2017, 01:24 AM Thread Starter
aprilia_rs250's Avatar
My bike arrived with a BS battery and BS battery charger. Zero instructions both in MV instruction/service and charger guides.
Is there a connector I can plug the charger to and not have to take the battery out?
Otherwise can just I plug the charger's red crocodile pin to + and - somewhere on frame? Will that screw something up?
Thanks in advance.
aprilia_rs250 is offline
post #2 of 5 (permalink) Old 07-18-2017, 05:26 AM
Tony F's Avatar
Does the battery charger have a connector plug? Yes? Look under the passenger seat, you should find a matching socket. It may have a rubber protective boot fitted.
Tony F is online now
post #3 of 5 (permalink) Old 07-18-2017, 05:37 AM
And if not. Yes, you can hook the red alligator clamp to + on the battery and negative to any solid mount on the frame. Even the engine block.
post #4 of 5 (permalink) Old 07-18-2017, 05:40 AM
@Tony F: Of course the battery charger has a connection plug. The process is outlined very nicely in the manual for your bike. Check the top of each maintenance section to figure out how to download your manual.
Name:  F4 Battery Charging Connection 2013.jpg
post #5 of 5 (permalink) Old 07-19-2017, 01:01 AM Thread Starter
Thanks guys
I managed to download the right manual now!
