2007 F4 312R dead Dashboard - need help... - MVAgusta.net
  • 2 Post By Spud
post #1 of 9 (permalink) Old 07-15-2017, 12:29 PM Thread Starter
Spud's Avatar
Guys
I was at Donnington yesterday and biek was fine until last session when the dashboard started lighting up like a xmas tree, and the rev counter going beserk.
Engine was still runninmg fine though.. came into garage and dash was completely blank, not 1 light etc
Today i have checked fuses and have checked that i'm getting power on the dash conenctor :-
<12v over pins 9(IGN) & 20(Gnd)
<12v over pins 10(BATT) & 20 (Gnd)
Also the Power Relay is working fine.
Engine turns over and fule pump is alive.
Battery showing 13v
Is there anything else i need to check ?
I would have expected that having 12v on pins 9/20 and 10/20 would have been enough to at least light the lcd or backlight ??
If it is the dashboard, has anybody taken one apart to check solder joints etc ??
[SIGPIC][/SIGPIC]
Spud is offline
post #2 of 9 (permalink) Old 07-15-2017, 12:53 PM
Have you disconnected, then reconnected the dash?
post #3 of 9 (permalink) Old 07-15-2017, 12:57 PM Thread Starter
Spud's Avatar
Yes still nothing.
But if i shake the dashboard i get some lights apear and disappear.. so must be internal break somewhere
[SIGPIC][/SIGPIC]
Spud is offline
post #4 of 9 (permalink) Old 07-15-2017, 01:04 PM
Sounds like a broken solder joint on the power supply
post #5 of 9 (permalink) Old 07-15-2017, 01:06 PM Thread Starter
Spud's Avatar
So is it a bin job then and go look for another display ??
[SIGPIC][/SIGPIC]
Spud is offline
post #6 of 9 (permalink) Old 07-15-2017, 01:13 PM
Not necessarily. Open it up and see what you see.
post #7 of 9 (permalink) Old 07-15-2017, 01:41 PM Thread Starter
Spud's Avatar
Well couldnt see anything obvious...
But took it completely apart - every screw removed and re-assembled...
And tested without the covers on... and blow me backwards it worked....
Replaced covers and still functioning.. crazy or what !!!
gotojoe and gotojoe like this.
[SIGPIC][/SIGPIC]
Spud is offline
post #8 of 9 (permalink) Old 07-15-2017, 01:59 PM
Sometime, it's just a dirty connection.
Glad to be of service.
post #9 of 9 (permalink) Old 07-15-2017, 05:19 PM
number2's Avatar
Fm!!
number2 is offline
