Are there alternate sprockets? - Page 2 - MVAgusta.net
post #11 of 27 (permalink) Old 02-07-2017, 08:51 PM
Talking wtf???.
the silliness that you people come up with amazes me.......
the chain sold by that eBay site is DID XV2...... it's X-ring too, anything wrong with this?
the sprockets are from AFAM, a well known supplier
the chain and sprockets are guaranteed for 15,000mi/24,000km
IF the CS sprocket nut is CORRECTLY torqued to 140Nm/103lbft it's not going anywhere even without LocTite
any of you look how Honda always mounted CS sprockets or Husky or Maico???? they are loose on the CS!!!
what good is a Scott Oiler on an X-ring chain???? it only cleans the chain....the X-rings keep the lube OUT of the roller chain
My 910R currently has over 33,000mi/53,000km+ on the original chain on occasion I wipe it down with WD-40
to keep it from rusting
post #12 of 27 (permalink) Old 02-08-2017, 06:02 AM
Bumpkin's Avatar
From my angle Noel I wasn't speaking about a specific supplier, just a general caution that all sprockets are not created equal. I've seen the results of in-precise fitting splines on an output shaft, all torqued up correctly. Admittedly not on an MV. End result was a replacement engine from a breakers yard as the most cost effective solution.
In your climate maybe, ride in plenty of rain and shitty conditions and a chain oiler makes more sense. Sure, a sealed chain requires no internal lubrication, but the sprockets and chain rollers can be prematurely worn by the grinding paste combination of chain lube, water and road grit. A chain oiler tends to carry this away. Are you saying that you use no lube at all, just WD40?
Donsy and Donsy like this.
Chas
Bumpkin is offline
post #13 of 27 (permalink) Old 02-08-2017, 08:27 AM
Wink
Originally Posted by Bumpkin View Post
Either that or fit a chain oiler and get to 30 - 40,000 miles before you have to think about changing.
When you ride like a pussy
post #14 of 27 (permalink) Old 02-08-2017, 07:43 PM Thread Starter
Reckler's Avatar
^^^Ouch, Dons, haha. I've got over 27k on the stock sprockets and chain. If I excessively clean, lube, and tighten them I can avoid a racket of clacking for a short time, but can feel the vibration at speed from the stretch in the chain. Too much throttle, all the time My last ride it was really bad, so I called it quits till I geab a new set for next season. At -32C it's not going anywhere soon
Yeah, the site on ebay sells the AFAM sprokets with various chain options. Pretty solid brands. Just vuri I us of options, I won't run questionable sprockets to save a few bucks, but I don't want to throw money away to banks and shippers if I don't have to.
Reckler is offline
post #15 of 27 (permalink) Old 02-08-2017, 08:10 PM
Thumbs up
Sounds like it's about time mate. FWIW, I wouldn't hesitate to buy from most of the eBay suppliers of chains and sprockets, there is a lot of options out there indeed.
Have you compared their prices with The Sprocket Centre's prices, I've bought some through them for other guys and it's a good comparison. ?
post #16 of 27 (permalink) Old 02-12-2017, 08:44 PM
Chas;
Yes, occasionally WD-40, NO CHAIN LUBE
1st you're riding on the street ....no slurry of mud, if you delete the chain lube there is nothing to keep grit around
2nd water is the Universal Solvent, it carries everything away
at 60mph your rear sprocket is turning ~840rpm the CS sprocket 2240rpm
so they are slinging the water and anything else off
like I said I have 33,000+mi on my chain and sprockets, the rollers are bright and shiny the chain has been rarely adjusted (when needed)
there is nothing wrong with running a Scott Oiler....... it's just not necessary with O-ring chains.....
on a 4 stroke dirt bike just route the crankcase breather to the inside of the bottom run of the chain.....lubed and clean
post #17 of 27 (permalink) Old 02-13-2017, 12:42 AM Thread Starter
Reckler's Avatar
Yeah, Dons, I priced out a few options for comparisons with The Sprocket Center. They have more selectable options to choose from and decent pricing, but with the Canadian dollar adding 30% and the flat shopping rate to Canada it makes the ebay option much more affordable...even from the UK. My choice could be made for me if the US cuts off trade with us, haha.
Reckler is offline
post #18 of 27 (permalink) Old 05-26-2017, 07:39 AM
Calcifur's Avatar
Sorry to Hi-Jack this thread! I am looking at a new chain and sprockets for my B4 750s and came across THIS on Ebay. 135 delivered for a DID 520VX2 chain and stock AFAM sprockets.
It seems like a good deal, but I have never bought chains or sprockets before so don't know the good from the bad. Just wondered if any of you with more experience have used these brands before and if so if they are any good?
Calcifur is online now
post #19 of 27 (permalink) Old 05-26-2017, 10:06 AM
Talking
You might want to check with someone, like forum sponsors, who actually have a picture (idea) of what Brutale or MV sprockets look like mate. I know often images are just generally shared, but I would check.
There will be more threads on this topic in the Performance section too.
post #20 of 27 (permalink) Old 05-26-2017, 07:20 PM
cus
cus's Avatar
Check too if they are for the original carrier or for a quick change carrier
cus is offline
