2013 F4 idle adjustment screw? - MVAgusta.net
post #1 of 4 (permalink) Old 12-10-2016, 09:33 AM Thread Starter
Clay1001's Avatar
Hey guys and Gals
Recently installed a QD Exhaust and remap but my Idle is running a little high. Is there an idle adjustment screw for this model and where would it be located. I have looked in the manual but can't seem to find anything on the subject.
Is it as simple as adjusting an idle adjustment screw?
Cheers Clay
IF LIFE THROWS YOU A CURVE, DROP YOUR KNEE AND RIDE THAT BITCH
Clay1001 is offline
post #2 of 4 (permalink) Old 12-10-2016, 11:41 AM
dansoarr's Avatar
On my 2015 the primary idle control is set in the ecu not by a screw. There is an idle map which is related to engine temperature.
I run a higher idle on track so I adjust that table, along with the temperature that the fan comes on at.
Hope this helps
Arron
Arron
2015 MV F4, ABS
ECU Mapped with ECUstudio
others
GSXR 1000
GSXR 750
dansoarr is offline
post #3 of 4 (permalink) Old 12-11-2016, 03:55 AM Thread Starter
Clay1001's Avatar
Thank you mate
What do you use to change the setting in the idle map?
Clay1001 is offline
post #4 of 4 (permalink) Old 12-11-2016, 04:13 AM
dansoarr's Avatar
I use EcuStudio, or your dealer should be able to correct it with thier Texa software. I'm not sure if Rexxer can do it or not with a custom map.
Happy to share my tables with you but you would require the ecu software
Arron
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is offline
The Following User Says Thank You to dansoarr For This Useful Post:
