750 SR shift issue - MVAgusta.net
post #1 of 38 (permalink) Old 10-20-2016, 11:31 AM Thread Starter
750 SR shift issue
Hi All. New to the forum, so I'll dive right in. I have a 2004 750 SR and I'm the second owner. The bike has a weird problem. To get back to neutral you have to slightly increase the revs or it won't go in. It also 'creeps' forward when stationary and in gear. The first owner (who is a friend) told me he spent a long time talking to MV about it and was told its a problem with all the SPR engined MVs.
Since I've bought the bike my local dealer swapped out my clutch for a standard 750 one and the problem went completely away. Put my SPR clutch back in, and the problem returns. MV don't seem to know why and also can't tell me why the SPR clutch does this. Anyone know anything about this problem? TIA.
MV SR Noel is offline
post #2 of 38 (permalink) Old 10-20-2016, 11:59 AM
Welcome...you are the second SR to join the family this month!
Where are you on this Big Blue Marble?
I suspect, if the problem isn't there with the standard clutch, but is there with the SR clutch, then there is an issue with the length of the clutch push rod.
That is assuming the system is well bled and no modifications have been done to the clutch lever or master cylinder.
post #3 of 38 (permalink) Old 10-20-2016, 12:03 PM
Al-
I had this issue with my spr also. I ended up replacing the clutch discs and steels and it went away. I think they had gotten a bit sticky from sitting over the years.
Al- is offline
post #4 of 38 (permalink) Old 10-20-2016, 01:19 PM Thread Starter
I'm in Dubai, UAE (but British, so not a native). My mate imported the SR from the factory in 04 as there was no dealer here. An official dealer opened about 6 months ago and have been really helpful.
I'll pass on the info to the dealer mechanic, as he taken this on as a sort of pet project, as he's annoyed he can't find the solution.
post #5 of 38 (permalink) Old 10-20-2016, 01:21 PM Thread Starter
Thanks for the info. Apparently its a common problem, but no-one at MV seems to know how to fix it. I already tried new discs and steels, but no luck. Now a new basket is arriving next week to see if that solves it. Might end up just fitting a standard 750 clutch to solve it, as I have a track bike, so the MV doesn't get used in anger too much.
post #6 of 38 (permalink) Old 10-20-2016, 01:48 PM
What is the difference between the SR clutch and the standard clutch?
post #7 of 38 (permalink) Old 10-20-2016, 04:12 PM Thread Starter
The plates are all the same, but the basket is slightly different (and the springs I believe). It's all very small differences, but enough to make a difference. We've asked MV (at factory level) if the standard clutch can cope with the SR power (plus mine is factory chipped). But unsurprisingly no-one there seems to want to answer that.
post #8 of 38 (permalink) Old 10-20-2016, 05:01 PM
You did not change the basket initially, and the clutch worked with the regular 750 plates.
Therefore, you can conclude that the basket has nothing to do with it.
It is in the height of the plate stack.
post #9 of 38 (permalink) Old 10-20-2016, 08:34 PM
First Welcome to the Forum Noel! .......from another Noel
750 clutches have 6 springs on the pressure plate and all the fiber discs are the same
910-1000S clutches have 4 springs on the pressure plate and the top and bottom fiber
discs are narrower than the rest.....
there is also a flat washer and a belleview spring on the hub under the 1st steel plate
(page G-09 of the 910 Brutale Parts Manual) items #17 & #18, flat washer goes on 1st
all the plates and discs must be flat.....
then bleed the clutch
http://www.mvagusta.net/forum/showthread.php?t=196585
if the fiber discs are in spec it will work.....
my vote, air in the system
Chuck; the hydraulics compensate for clutch wear automatically, push rod length too
post #10 of 38 (permalink) Old 10-20-2016, 08:50 PM
Send a message via Skype™ to Ian SAVS
The Senna 750, the SPR and the SR all got an upgraded "stronger" clutch. Don't know yet what parts were different.
Ian SAVS is offline
