2010 1090rr Tach frozen. - MVAgusta.net
post #1 of 3 (permalink) Old 08-14-2016, 11:42 PM Thread Starter
kbw
kbw's Avatar
Hi All,
Sometimes my tach will freeze up around 2-3k on its revolution at start up or while I'm riding. It doesn't stay stuck at that position, it's more like that 2-3k becomes the new zero and it shows that I'm at higher revs than actual.
I initially thought it was a battery issue as I was also having problems starting, but I replaced the battery and that didn't fix either issue. Ended up being the starter relay causing the starting problem, but I replaced the relay and the starting problem is resolved, but the tach problem remains. It seems to happen more often on hot days, but I haven't verified that idea
Any ideas oh MV gurus?
kbw is offline
post #2 of 3 (permalink) Old 08-15-2016, 04:46 AM
Yes, there are ideas and it is not an uncommon problem.
If you remove your dash cover, unplug the harness from the back of your dash, then use a quality contact cleaner on both the dash and its plug, then reassemble using an electrical contact grease, the problem should go away.
post #3 of 3 (permalink) Old 08-15-2016, 08:36 AM Thread Starter
kbw
kbw's Avatar
I'll try that and see if it helps. Thank You!
kbw is offline
