2007 F4 1000R headlamp problem - MVAgusta.net
post #1 of 43 (permalink) Old 08-13-2016, 07:01 AM Thread Starter
Hi all,
Bike is 2007 F4 1000R, first registered Jan 2009, 21k miles.
Jen brought the F4 R home complaining the high beam was out.
Checked fuse, fine, even replaced it to be sure, meter test fine.
Bulb pulled, checked fine, used a meter on it so no doubts.
Relay, pulled swapped with a known good one still lamp out.
Anybody had similar issue if so what was it?
jimboF4 is offline
post #2 of 43 (permalink) Old 08-13-2016, 07:43 AM
Did you put the meter to the hot supply of the bulb, with the bike running and high beam activated?
Possibilities include a bad ground connection, a bad power lead, a faulty hi/lo switch.
post #3 of 43 (permalink) Old 08-13-2016, 07:49 AM Thread Starter
Thanks I'm back out to the garage now.
jimboF4 is offline
post #4 of 43 (permalink) Old 08-13-2016, 09:31 AM Thread Starter
Right no supply to the bulb, tested with meter, looking at switch now.
One thought, could it be the projector light itself?
jimboF4 is offline
post #5 of 43 (permalink) Old 08-13-2016, 09:32 AM
There is prbaly an open in a wire somewhere.
It's continuity check time.
post #6 of 43 (permalink) Old 08-13-2016, 09:41 AM Thread Starter
Cheers Chuck, marvelous best days weather we have had here for days and I'm sweating my plugs off with a meter stuck in the garage!!
jimboF4 is offline
post #7 of 43 (permalink) Old 08-13-2016, 09:59 AM
I am in the garage off and on today myself...we have been hot, hazy, and humid for a week now.
I love it, but I also have a big ol' pool to jump into when I have had too much of the good weather!
post #8 of 43 (permalink) Old 08-13-2016, 10:30 AM Thread Starter
A big old pool would be good, my hot tub just not the thing on days like this, Weber z lot more cold than hot!
Right switch seems good, even flash to pass switch seems OK so where now, I hate MV wiring costs.
jimboF4 is offline
post #9 of 43 (permalink) Old 08-13-2016, 01:54 PM
Hi Jim.
You probably know that there are two relays . One for high beam and one for low beam...Just in case..
Hi Chuck ..How are you doin out in cooking Massachuaetts !
Joe
gotojoe is offline
post #10 of 43 (permalink) Old 08-13-2016, 02:46 PM Thread Starter
Hi Joe.
Yeah went straight to them after the bulb, in the end got fed up it was hot here so rode to the pub for a couple of cold ones. It can wait until tomorrow now.
jimboF4 is offline
