2006 Brutale 910S Now Won't Start: SPU? More? - MVAgusta.net
post #1 of 4 (permalink) Old 06-21-2016, 03:42 PM Thread Starter
Samurai Jack's Avatar
Unhappy 2006 Brutale 910S Now Won't Start: SPU? More?
Hi all,
Short story:
I washed my '06 Brutale 910S and stared it up, but ran out of time to take it on the first real ride this year. Put it away. Took it out two weeks later, and hit the starter. Was surprised when it didn't grumble to life, and I thought I heard a whine. Tried again and only got a CLICK. Several times just a CLICK. Then...nothing. Dash and gauges on...but no starter action. Charged it overnight (with a "smart" tender/charger via the quick connector with the battery in the bike). Next day, same story...absolutely nothing when I hit the starter switch. I've never replaced the SPU. Is it the obvious culprit here? Should I check a few other simple things? I've always "wanted" to upgrade the SPU since I always had minor wonky headlamp / left turn signal / engine stall annoyances that I knew were related...but now it just won't start. Different problem entirely or related?
Full history (beware all ye who enter here)
My '06 Brutale 910S has always had some electrical gremlins: a haunted headlamp that sometimes flicks to high beams and back to low on its own...a left turn signal that doesn't always light when I flip the switch...and the occasional engine stall that was always easy enough to recover from with a flick of the starter (if a more than a bit worrisome for what might happens in a hairpin under power).
Last couple years it's been ridden only infrequently. Last year the battery seemed to be somewhat "drained" when it shouldn't be (after a ride or just sitting there for a time). I have a red/yellow/green indicator on the quick connect of my "smart" tender/charger and it was going yellow all the time for no reason. Eventually I was mid ride and it just went dark..no electrical...just dead. The battery seemed to be gone, so I bought another Yuasa YTZ10S, had a basic check-up service done (oil/filter/tune-up, etc) at my MV dealer, had them make sure it seemed right to them and I was back in business. They seemed to believe I might have some kind of voltage drain "somewhere"...but this remained a minor mystery to be forgotten about since it was running well again. Even the turn signals and headlamp demons seemed to be miraculously exorcised!
This year I took it out, washed it off, cleaned the chain, started it up. Ran out of time to really go for a ride, and had to put it away.
Two weeks later I'm finally geared up to do a long ride, so I switch it to ON, watch the needle do it's thing around the tach, disengage the red kill switch (yes, I did this!), get it in neutral, kickstand up, clutch held in, hit the starter. ... I'm surprised when it doesn't fire up. I think I hear a kind of whine. Hit starter again, I hear only a CLICK. I try a few more times and get only a CLICK. Now I try again and I get nothing. Not even a click.
I put the bike on the charger and let it go overnight. Next day: dash/gauges are on, but starter button has zero effect. No click, nothing. I think I remember that I didn't see the green N light even though it was definitely in Neutral. But I had the kickstand up and the clutch in, so I have no idea why that would even matter...but it does smell of more electrical weirdness.
I'm planning to check (wiggle? clean??) the clutch switch, the kickstand switch, and the gear selection switch. I'm planning to check for loose or burnt/melted connectors at the starter relay. I'll check for blown fuses on the starter relay and on the existing (old) SPU. Regardless of the no-starting problem, I will do the SPU replace. Is there any hope if I don't see anything else obvious that this is the whole problem? Is it a bad idea to plug in the new SPU part if I don't have an expert look for a short somewhere that I can't find? I don't want to have to rent a trailer to get it to the MV shop (again!) if I haven't done at least a little common sense work myself to avoid an even bigger expense here...but in the end I just ant to know it's finally put right and I can rely on it reasonably.
Did that whine->click->nothing indicate my starter solenoid is dead? Can I just short it to diagnose?
Each moment, only once.
Samurai Jack is offline
post #2 of 4 (permalink) Old 06-21-2016, 06:37 PM
I'd replace the battery 1st, or at least remove and charge with a decent charger. The whine/click you hear is fuel pump priming, the rest sounds like low battery.
post #3 of 4 (permalink) Old 06-23-2016, 08:16 AM
...or a loose battery connection.
Check tightness and condition of grounds and battery connections.
post #4 of 4 (permalink) Old 06-25-2016, 07:16 PM
1st take a picture of the battery connections......
remove it and charge it .....take the battery to an auto parts store and have it load
tested, don't go to a motorcycle shop they'll want to replace your 2 year old battery
Buy a little tube of dielectric grease
Clean both ends of the battery cables and the wires to the solenoid apply the grease
The battery goes in on its side!!!! check your picture
It should start.....push start if necessary..... measure the system voltage at idle
Report back
Check the color of the back of your SPU if it's blue that's the cause of the goofy stuff
There is a sticky at the top of the Brutale section with the correct part number for your
bike it goes by VIN
