2009 Brutale 1078RR cooling issue - MVAgusta.net
post #1 of 16 (permalink) Old 05-29-2016, 06:50 PM Thread Starter
Hello Gentlemen, as stated above I have a Brutale with a cooling issue.
Every fall I drain the coolant and refill in the spring due to very cold winter temps where I'm at.
This has never been a problem in the past but this year my coolant temperature gauge on the dash is acting very strange.
It will indicate as high as 290 degrees Fahrenheit and it fluctuates by as much as 25 degrees very rapidly.
As soon as I noticed the temp being so high I pulled over and checked coolant level and there was no visual indicators that I was overheating or low on coolant.
I rode the bike home figuring that perhaps I had an air bubble trapped in the system somewhere.
I got it home, drained and filled the system carefully (shaking the bike and periodically starting the engine) and I still have the same problem. I let the bike warm up and the dash indicates 250 degrees at idle with the fans running, so I checked temperatures in various places on the cooling system with an infrared thermometer and nothing is above 200. The water pump housing was indicating 150 degrees.
So this leads me to believe that I have a bad temperature sensor, could I please have some opinions on this, and where exactly do I find this sensor and test it?
Thanks in advance gentlemen.
wildbill is offline
post #2 of 16 (permalink) Old 05-29-2016, 07:07 PM
Post
Hi Mate, have you downloaded the Workshop manuals yet?
The sensor which signals the display on your bike is mounted on the radiator.
post #3 of 16 (permalink) Old 05-29-2016, 07:31 PM Thread Starter
Donsy, it is telling me permission denied.
wildbill is offline
post #4 of 16 (permalink) Old 05-29-2016, 08:11 PM
Check you PC browser setting mate.
post #5 of 16 (permalink) Old 05-30-2016, 04:01 AM
eddypro's Avatar
Donsy ,no sensor on the Rad,sensor is the other one,to many bloody types ,LOL
eddypro is offline
post #6 of 16 (permalink) Old 05-30-2016, 04:06 AM
eddypro's Avatar
my 1078b
eddypro is offline
post #7 of 16 (permalink) Old 05-30-2016, 05:22 AM
Thanks Eddy, I always forget if the 910R's or the 1078's had the two sensors.
post #8 of 16 (permalink) Old 05-30-2016, 05:59 AM
eddypro's Avatar
Donsy ,I get them all mixed up
eddypro is offline
post #9 of 16 (permalink) Old 05-30-2016, 06:41 AM
BG Wells's Avatar
Yep..no sensor on the Brutale 1078rr radiator...
Here are a couple of photographs of mine..
Brian
BG Wells is offline
post #10 of 16 (permalink) Old 05-30-2016, 07:52 AM
hb88xx's Avatar
neither My 910r euro3 has a sensor in the rad either. So which ones have?
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
