05 F4-1000 plug where at? for VDST - MVAgusta.net
post #1 of 18 (permalink) Old 05-21-2016, 03:18 PM Thread Starter
PhilAgusta's Avatar
I found a plug under the seat next to ecu on my f4-1000 but that one doesn't communication with VDST, what is your advise should I do?
Best,
Phil
07-MV Senna 201/300 My wife gift for my BD
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
09-Ducati 848 Her bike turn in track bike
PhilAgusta is offline
post #2 of 18 (permalink) Old 05-22-2016, 08:41 AM
Name:  F4 750 Diagnostics Connection.jpg
post #3 of 18 (permalink) Old 05-22-2016, 09:13 AM Thread Starter
PhilAgusta's Avatar
Thank you Chuck, but 05-F4 hidden the plug some where, I went to cable from ECU to always to fuel injection to headlight cable none have extra plug beside the one under seat.
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
post #4 of 18 (permalink) Old 05-22-2016, 09:41 AM
Sorry Phil!
I don't know why I was thinking F4 750...
Here is where the parts manual shows the Diagnostica Connection:
Name:  F4 1000 Diagnostic Connection.jpg
This is also where it is on the later first generation bikes. There is a physical cap over the end of the connection, but it is simply lying in the seat tray.
post #5 of 18 (permalink) Old 05-23-2016, 09:15 AM Thread Starter
PhilAgusta's Avatar
Thank you Chuck, but I can't get the VDST from Technoresearch reading from the plug, have anyone on here try that? if so what is your system or software that you guys using?
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
post #6 of 18 (permalink) Old 05-23-2016, 10:01 AM
If you have the 5SM Magneti Marelli ECU, and you should, then Techno Research VDST is correct.
That is the tool that I use for my 312R and Brutale 1090RR. Are you sure you are set up correctly?
post #7 of 18 (permalink) Old 05-23-2016, 10:08 AM Thread Starter
PhilAgusta's Avatar
I need a signal from the plug on bike to my pc but no signal so I can't get it communication to each other? I pluged in my 07-Senna it talked with each other so can get the reading on my screen pc
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
post #8 of 18 (permalink) Old 05-23-2016, 10:12 AM
Interesting, Phil...and annoying, I'm sure.
Have you checked the other end of the ECU/VDST Plug?
(I am not at home, so I can't go out to a bike and check things...)
post #9 of 18 (permalink) Old 05-27-2016, 10:48 AM
Phil can you verify your cables work on the duc first? I have the same VDST and it worked on my 05 and my 07. HOWEVER I did find that it can be a little funky about com ports. Have you tried to use GUZZIDIAG? it works in my opinion better.. I also have an app that I paid for on Android only.. TuneECU,
I will be happy to drop the Guzzi files to you via gDrive or dropbox.
One other thing is that if you bought your fiat cables separate from the TechoResearch you may have to solder pins 4-5 together because there is a difference in the chipset and they dont bond the ground to the correct pin.
Im not saying kill all the stupid people, but lets remove the warning labels and let nature sort it out...
FL Ogborn is offline
post #10 of 18 (permalink) Old 05-27-2016, 10:49 AM
sorry didnt see that you already had it communicating to your other MV.
