Cam chain tensioner - MVAgusta.net
 12Likes
post #1 of 152 (permalink) Old 03-16-2016, 12:57 PM Thread Starter
swissinn's Avatar
Cam chain tensioner
I know it's been on here a million times but I went at it from a different angle. The spring in this pic had nothing stopping it from popping straight out of that opening. In fact when I removed the Cam chain tensioner the spring was almost popped out. If it comes out and there is no more tension on the ratchet, it's easy to predict what will happen...kaboom. So I took it apart and drilled a recess into that part so the spring is captured and has nowhere to go. $20 says that spring coming out is responsible for all the engine failures. Hopefully I just saved myself $450. We shall see.
Ex Silentium Adveho Nex
swissinn is offline
post #2 of 152 (permalink) Old 03-16-2016, 06:05 PM Thread Starter
swissinn's Avatar
Don't know if you guys knew this but the Cam chain tensioner on the first gen F4 1000 is IDENTICAL to the one used on the Kawasaki KX250F Dirtbike, the RMZ250F Dirt bike. They cost $77 USD. Your welcome. BTW there is lots of aftermarket tensioners available for those machines and they cost about $100. Check out Tokyo mods. They have a beautiful manual adjuster that will never ever break.
swissinn is offline
post #3 of 152 (permalink) Old 03-16-2016, 06:09 PM
Maximum Velocity's Avatar
Is the original also not around 100?
What a beast of a motorcycle!
Maximum Velocity is offline
post #4 of 152 (permalink) Old 03-16-2016, 06:34 PM Thread Starter
swissinn's Avatar
$298.00...
swissinn is offline
post #5 of 152 (permalink) Old 03-16-2016, 07:15 PM
Dave;
the usual failure is the casting cracks through the pivot point killing tension on the
ratchet.......
thanks for the alternate sources
post #6 of 152 (permalink) Old 03-16-2016, 07:39 PM Thread Starter
swissinn's Avatar
For $100 this will certainly outperform the $298.00 upgraded MV version.
swissinn is offline
post #7 of 152 (permalink) Old 03-16-2016, 07:44 PM
eddypro's Avatar
Even if the spring fails ,the shoe can not retract .But swiss good idea.
cheers eddy
eddypro is offline
post #8 of 152 (permalink) Old 03-16-2016, 08:11 PM Thread Starter
swissinn's Avatar
I just ordered this tensioner so I'll let you know how it works out. Cost $150CAD shipped. MV wants $450CAD plus Tax...eesh.
swissinn is offline
post #9 of 152 (permalink) Old 03-16-2016, 08:22 PM
Good info, thanks for that mate.
post #10 of 152 (permalink) Old 03-16-2016, 09:23 PM
revhead1957's Avatar
Once it has been verified this needs to go into the sticky section. Last time I checked the std tensioner was priced at A$495 in Australia.
Can't say I agree with the post above. If the spring pops out the only thing holding the ratchet in place is tension, which will be changing as you throttle off.
This whole subject does my head in. Other brands have issues too. Wish there was some way to have gear driven cams, like the older MV and the Honda VTR SP's.
revhead1957 is offline
