Cam chain tensioner - Page 14 - MVAgusta.net
 12Likes
post #131 of 152 (permalink) Old 03-24-2019, 12:28 PM
F4rr
Got motor valve cover off and under close inspection there is a tiny bit of slack in the timing chain with original TCC in place working properly , I am no expert here but I am leaning towards the conclusion that the stock TCC does not put enough pressure on the timing chain guides which in turn causes a bit of slack and the noises we are hearing !
at 17,000km i even took it upon my self to install stock (BLACK) TCC in my bike and once TCC had pushed to its desired location , i made a small rod or a drift pin to carefully advance the TCC one tooth more , then i installed a small ball bearing on the back side of the spring that is loaded into the TCC , I did this to add a bit more PUSH or pressure resistance on the chain , i also made the rod that goes into the TCC almost exactly the length of the void inside the TCC to insure that the TCC could never back out as some have experienced.
I will be getting the manual TCC and see if this helps most have said it will , i will also be installing it with a new timing chain , I will be rotating the motor once installed and be checking chain at several different timing locations to see if there is any difference in tension ,
will post pics soon
rulookin is offline
post #132 of 152 (permalink) Old 03-30-2019, 03:56 PM
ViggenF4's Avatar
First thing to do now is to do nothing!
You need the slack in the chain, if you tighten it away, it will snap 100%. It will have approx 1,5 mm of play between the cam gears when normal tightness.
DO NOT OVERTIGHTEN IT!
revhead1957 and nigelrb like this.
ViggenF4 is offline
post #133 of 152 (permalink) Old 04-01-2019, 01:58 PM Thread Starter
swissinn's Avatar
It should only move a few mm when actually forcing it with your fingers. I hope that's what you meant. There should be absolutely 0 slack while it's just sitting there. Should be taught.
Ex Silentium Adveho Nex
swissinn is offline
post #134 of 152 (permalink) Old 04-02-2019, 02:09 AM
ViggenF4's Avatar
Thats what i meant. I wrote about that on my thread earlier, on 750/910 hybrid thread. I used spring scale when i pulled between the cam gears, if i remember correct it was 5kg and 1.5mm.
ViggenF4 is offline
post #135 of 152 (permalink) Old 04-02-2019, 02:15 AM
ViggenF4's Avatar
Correction. It was 4kg and 1.65mm...
ViggenF4 is offline
post #136 of 152 (permalink) Old 04-16-2019, 07:08 AM
Midnicrow's Avatar
Has anyone successfully used the Kawasaki CCT suggested earlier in this thread? Back then it was 77 now 114.
James M.
Midnicrow is offline
post #137 of 152 (permalink) Old 04-16-2019, 06:56 PM
GOT MY kx 250 cct IN MY BIKE ~! was installed when i was haveing valve clearances checked so the timing chain was exposed
rulookin is offline
post #138 of 152 (permalink) Old 07-05-2019, 01:57 PM
Robbedoes's Avatar
Does anybody know where to source the Tokyomods tensioner in Europe? I can't find it anywhere and at worldwide shipping US shops it has been out of stock for months. And vivid racing does not reply to my (multiple) shipping quote request(s).
2003 MV Agusta Brutale 750S
Robbedoes is offline
post #139 of 152 (permalink) Old 07-05-2019, 04:06 PM
Robbedoes's Avatar
Anybody know if this shop is legit?
https://www.camchaintensioner.co.uk
post #140 of 152 (permalink) Old 07-06-2019, 01:37 PM
ViggenF4's Avatar
Seems like an quality items, i would use them!
ViggenF4 is offline
