Cam chain tensioner - Page 11 - MVAgusta.net
 12Likes
post #101 of 152 (permalink) Old 09-09-2016, 11:32 AM
anyoldiron's Avatar
Originally Posted by revhead1957 View Post
I think the point is being missed here. Correct me if I am wrong, but like the final drive chain, the driven side will always be under tension when the motor is running, so the valve timing will not change.
The function of the tensioner I would have thought is merely to stop an overly slack cam from slapping around as heat expansion and wear occurs.
So, my answer would be to set it on the loose side and forget about it for 10,000 kms. I have regularly popped the valve cover to check the CCT, and the adjustment required is minimal. FWIW I have cut a longer internal rod for the CCT so that if the ratchet ever fails, the plunger cannot retract enough that the chain can skip a tooth.
l think this is a great idea, can you please post details?
anyoldiron is offline
post #102 of 152 (permalink) Old 09-12-2016, 07:22 PM Thread Starter
swissinn's Avatar
I'm glad you guys are having success with this CCT. For the few thousand kms I had it it was so quiet and enjoyable to ride.
Ex Silentium Adveho Nex
swissinn is offline
post #103 of 152 (permalink) Old 01-27-2017, 01:43 PM
Nitro69's Avatar
Does anyone know if the kx250f tensioner will work on a 2010 f4????
Ride it like you stole it!!!
'10 F4,'98 Buell S1w,'92 ZX-7
Nitro69 is offline
post #104 of 152 (permalink) Old 01-27-2017, 09:29 PM
Draginknee's Avatar
No reason why it shouldn't, it's all the same for all the 4cyl MVs. I plan on putting one in the 12' Brutale before too long as well.
"When you cannot ride de bike, you are very quiet at home in de sofa." -Rossi
I'm Curtis...
Email:
Facebook:
For used MV parts, look up my ebay user ID; "cbmx101"
Draginknee is offline
post #105 of 152 (permalink) Old 09-20-2018, 05:52 PM
budgienutz's Avatar
Any particular year model for the kxf250 cct?
Ready to order,just dont want to order the wrong year if there is a difference.
budgienutz is offline
post #106 of 152 (permalink) Old 11-20-2018, 06:31 PM
So is this KX250f CCT still the way to go over the updated black CCT? For an 05 F4 at 5k.
CessnaA&P is offline
post #107 of 152 (permalink) Old 11-21-2018, 07:59 AM
Some would say yes; some would say no.
Depends on your ability to adjust the manual tensioner over time.
racasey likes this.
post #108 of 152 (permalink) Old 11-21-2018, 10:51 AM
Yea I’ve done a Jetprime pump,Samco hose kit with clamps, Muzzy fans, Brembo wheels, full radial brake conversion and all miantanance on my bike. I’d say an adjustment every 5k to 10k would not be a problem. Thank you Sir for your advice
silentservice703 likes this.
post #109 of 152 (permalink) Old 11-22-2018, 10:27 AM
ViggenF4's Avatar
I say yes, go for the manual CCT.
ViggenF4 is offline
post #110 of 152 (permalink) Old 11-22-2018, 10:34 AM
Tokyo Mods CCT on the way off Ebay for $86 shipped.
