2010 990R won't start ... - MVAgusta.net
post #1 of 8 (permalink) Old 02-18-2016, 04:25 AM Thread Starter
BlackNinja's Avatar
*** SOLVED *** Culprit was a melted solenoid relay Connector ...
My 2010 990R wont start. When turning on the ignition the lights & dash come on, the pump primes and it wont start on the button. The battery is fully charged ..
I can hear a noise from the area of the box on the left (ECU?) - this video records the noise.
https://youtu.be/qTOxirhvjyI
Where do I go with this one guys ?
Also of note and possibly related is that there was a problem a while back where all electrics failed totally for a bit, as in when riding the bike one day it cut out totally, rolled on for a while with momentum but I managed to start it again with some frantic lever/button/key turning action. That might be related but it did start after that incident for a few weeks and its not been used since for about 3 months.
2010 Brutale 990R
BlackNinja is offline
post #2 of 8 (permalink) Old 02-18-2016, 05:45 AM
Could still be the battery, my 990r did the same thing a few years ago. Battery had full power with a voltmeter but had no current carrying ability. Press starter button and nothing. New battery and all good.
2017 Aprilia RSV4 RF
2015 Brutale Corsa
2014 F4
2014 F3 800 (wife's)
2012 Monster 696 (wife's)
2011 Brutale 990r
ontariomystic is online now
post #3 of 8 (permalink) Old 02-18-2016, 11:21 AM
Cold Cranking ability ;-)
MV Brutale 920 2012 White - Current
MV F41000R 2007 Black/Silver/Red - Gone
Bikerzz is offline
post #4 of 8 (permalink) Old 02-18-2016, 04:45 PM
Download the manuals, have a read through them and familiarise yourself with your bike buddy. On a bike, as in cars etc, there is only one left side and this is determined when you sit on the bike.
Have a look under your seat if you don't have the melted starter solenoid connections which is a fairly common later model Brutale issue ( You will see more examples here in the Maintenance section and the Tech Tips section).
I'd replace the battery after checking all connections, that sound is much like a really not latching because of low Voltage.
post #5 of 8 (permalink) Old 02-19-2016, 05:10 AM Thread Starter
BlackNinja's Avatar
OK - the solenoid connector is busted ... do I just pull the wires and fit into a new connector? Could water under the seat have caused this ?
In the meantime I'll check for any obvious cause. I already had issues with the clutch switch and the starter button .. bloody electrics!
2010 Brutale 990R
post #6 of 8 (permalink) Old 02-19-2016, 06:20 AM
This is a common occurrence on that particular connector. It is a high current draw and it tends to corrode over time. That connector, and your battery connections, should be periodically cleaned and treated with a grease specific to electrical connectors.
post #7 of 8 (permalink) Old 02-19-2016, 09:27 AM Thread Starter
BlackNinja's Avatar
Thanks. This got me going Will get some new spade connectors and use that electrical grease ...
2010 Brutale 990R
post #8 of 8 (permalink) Old 02-19-2016, 05:16 PM
You're welcome mate.
