Turn signals not working (strange) - Page 3 - MVAgusta.net
post #21 of 30 (permalink) Old 08-21-2015, 04:37 PM
borg4life's Avatar
my 2007 F4 does exactly what you describe. same blinker work - don't work pattern when hot or cold. I have no suggestions for you - only empathy. Let me know when you figure it out.
2007 Senna 1000R
2014 BMW S1000RR
1971 BMW R75/5
2004 Yamaha R1
Honda VFR 2000
Honda VFR 1993
Honda VFR 1987
Honda Shadow 500
Crappy Moped
borg4life is offline
post #22 of 30 (permalink) Old 08-21-2015, 05:53 PM
Lightbulb
Read his last post
post #23 of 30 (permalink) Old 02-05-2017, 09:52 AM
JRadicalF4's Avatar
So I ordered a new turn sigal relay from Superbrighleds. It works then it blows the fuse. But when I was riding yesterday it worked fine. Then when I came home to show a buddy that I fixed the problem with the bike on and not running its blow the fuse.
JRadicalF4 is offline
post #24 of 30 (permalink) Old 02-05-2017, 01:52 PM
Time to look for a ground in the circuit...or that you got a relay without the counter EMF diode.
post #25 of 30 (permalink) Old 02-10-2017, 03:49 PM
JRadicalF4's Avatar
Ok I got turn signal relay and worked for 2 seconds then it blows a fuse again. I don't understand
post #26 of 30 (permalink) Old 02-11-2017, 03:00 AM
noggin's Avatar
Short circuit somewhere causing the fuse to blow?
noggin is offline
post #27 of 30 (permalink) Old 02-11-2017, 06:54 AM
JRadicalF4's Avatar
Yep!! So after taking a step back an a beer or two I found the problem to my relief. The wires to the turn signals where indeed grounding out.
Thanks again for the help guys!!
post #28 of 30 (permalink) Old 02-12-2017, 04:32 AM
gotojoe's Avatar
Good to see you found it. Where was the fault. It helps if we learn where the issues arise.
joe
gotojoe is offline
post #29 of 30 (permalink) Old 02-27-2017, 05:18 PM
Lord Wukits's Avatar
I am very interested in this as well. I know I had issues with some parts of the wiring harness that I had fixed, but nothing with the blinkers. It was not till some time later that I noticed the indicators did not work[Ok ok someone told me. who looks at the cluster anyways? ]
2009 MV Agusta F4 1078RR 312 1+1
2006 Ducati 749 Dark
Lord Wukits is offline
post #30 of 30 (permalink) Old 04-24-2018, 07:47 AM
Midnicrow's Avatar
Try this diagram as a rough guide...
Joe
Wow! Thanks for this diagram exactly what I was looking for. Turn signal issues
James M.
Midnicrow is offline
