What do you do when the cager in front of you leaks engine oil - MVAgusta.net
post #1 of 7 (permalink) Old 01-02-2007, 07:05 PM Thread Starter
Was riding on the I 10 freeway in Los Angeles on New Years. Cruising at 70 mph, when an SUV right in front of me belched a huge load of engine oil, coughed up some junk from the hood, and stalled on the freeway. I managed to stop uneventfully, but my MV and me were covered in a layer of engine oil. The bike tires started slipping and I had to slow down to a crawl and pull over on the shoulder.
I was lucky and I did not slip and slide off the bike after going over a whole section of the road bathed in engine oil. What I want to know is if I fell and got injured would I trear it as just my bad luck or is the SUV at fault?
I know this is probably a rare occurence, but this event got me thinking. Anybody have had such events, or know what to do in such a scenario.
mv4avi is offline
post #2 of 7 (permalink) Old 01-02-2007, 07:33 PM
fazer6's Avatar
Hmm, dunno. On my way to the group ride yesterday a Ford diesel pick-up was spitting fuel in his exhaust and i didn't notice until I was covered in a fine layer of muck. I had to stop to wash my visor, but my poor bike had to wait until after the ride to be attended to.
I would assume it wouls be the same as a rock-chip. If you can identify the vehicle respnsible you can usually hold them responsible.
P.S. I'm glad you're ok, it could have been much worse, like you said.
fazer6 is offline
post #3 of 7 (permalink) Old 01-02-2007, 10:31 PM
lewdog998's Avatar
Generally speaking (from a liability standpoint)
anything already on the road that is picked up and thown onto any vehicle behind it, is considered "road hazard". If it was a rock, bolt, retread or whatever, the vihicle that hit it and caused it to become airborne is not liable for any damage to your vehicle, broke windshield paint damage etc..(bodily injury, I dont know for sure, as I have no experience with any injuries)
On the other hand....If the object or hazard was a part of, or came from the vehicle ahead, then it would in fact be liable. One example is dumptrucks...carrying gravel or whatever...anything that is seen flying out and hits something, then he is liable...that is why most states require all loads to be tarped.......
But its interesting to note that if you cannot the pinpoint the vehicle from which it came, then it is roadhazard.....
You will also notice alot of dumptrucks have the "stay back 300 ft, not responsible for road objects" This is tricky in that the average person will assume that the truck is not responsible for all the crap flying out of his truck (which in fact he is) but the warning is correct because they state "road objects" which is in fact anything already on the road aka road hazard.
so I would think that anything (including oil spewing out) would be the responsiblilty of the spewer, including any damage caused by it.
lewdog998 is offline
post #4 of 7 (permalink) Old 01-03-2007, 12:15 AM
agusta01's Avatar
There was an interesting discussion about tyres and oil, if I remember the story correctly, a rider wheelied a duc, a whole heap of engine oil coated the rear tyre, tyre manufacturers all recommended replace tyre....although the oil can be cleaned off with various solvents, the pores in the rubber retain the oil residue and will exude this once tyre reaches operating tempreture again, so the tyre may look 'clean' however it may become a real danger when ridden....I'd check this out if your tyre was oil soaked!
agusta01 is offline
post #5 of 7 (permalink) Old 01-03-2007, 11:22 AM
Something similar happend to a somewhat accident prone friend of mine, the same guy hit a sea gull at about 70 and broke his arm in the process. He was tooling around the backroads in CT, crested a hill and was greeted by several gallons of home heating oil all over the road. Lost control of the bike, slid down the hill and whacked the curb. Apparently a heating oil truck had spilled oil all over the street, causing the accident. The trucking company was fined, and the repairs to the bike and medical expenses were paid....similar situation but not quite the same.
Some Guy is offline
post #6 of 7 (permalink) Old 01-03-2007, 12:10 PM Thread Starter
Thanks agusta01 for the tire tip. I will have it checked. Ya, it was not a fun way to start off the new year. But then again it is a Los Angeles freeway. Engine oil is a petty thing compared to car drivers shooting at each other.
mv4avi is offline
post #7 of 7 (permalink) Old 01-05-2007, 12:58 AM
GL 21's Avatar
another thing to keep in mind is that most oils break down rubber over a period of time. this is most likely the reason that they call for replacement.
The only reason i say this is Aircraft tires are also made of a fairly soft compound. Engine oils, hydraulic fluids are all a serious no no to spill on the tires.
Just something to keep in mind.
'DOnt act like your not ImPREssed"
GL 21 is offline
You may post new threads
You may post replies
