Piqued by a thread on rear facing cameras.
I was reminded of a conversation between myself and a biking friend on why we still use mirrors on a bike. With technology the way it is, why don't we use rear facing miniature cameras on to a HUD (Head Up Display) monitor in the "cockpit). The display could be a dedicated part of the existing LED Console. Surely this would be safer than misaligned mirrors, that on most bikes just show you where your elbows are.
It would be nice if MV were to spearhead this kind of safety enhancement. It would also reduce drag and weight, which with the philosophy of drag and weight equalling slow, then it has to be a performance enhancement too.
The only proviso is that if they are fitted they must be functional. (I am told). which is the same for a headlight, which is just as likely to suffer a malfunction as a rear facing camera, which would only result in you having to look behind you if it malfunctioned, which we all do anyway, even with mirrors. So not such a difficult task to justify.
The legislature for the rest of the world may well differ, but I suspect there are less restrictions in most places than in UK, we have the most severe fun police.
Here in the States some require mirrors to pass inspection. Never mind if they function or not, they have to be installed. Like the man said good luck getting the rules changed/modified.
I suppose you could fit two monitors, one in each mirror,:tongue: actually, not as daft as it sounds, as you would probably keep looking at that area wondering where they were anyway Lol. You would still improve vision as you would be able to set the cameras up for a wider angle of view (and no elbows).
Years ago, I had the idea of using the F4's mirror housing for the location of the monitor -and there's a powered wire there due to the tire signs. I just don't have the electrical knowledge to make it work.
Don't you guys have enough electronic crap already?
Related Threads
MV Agusta Forum
1M posts
55.7K members
Since 2005
