What dealer returns calls? - MVAgusta.net
post #1 of 11 (permalink) Old 07-01-2010, 06:55 PM Thread Starter
Looking for a coolant overflow cap. Dealer in SA was supposed to call me back with a price and availibility. Havn't heard from them Dealer in OKC hasn't answered my email. Who is a good dealer to order from?
SpeedwayRN is offline
post #2 of 11 (permalink) Old 07-01-2010, 07:20 PM
Dealer?
Damn son, use your sources!
How many do you want? I have a lot you can have for the price of postage.
post #3 of 11 (permalink) Old 07-01-2010, 07:37 PM Thread Starter
Thanks! I need just one.
Yeah, dealers are easy to find. I just don't know who the good ones are.
I'm getting coolant overflow at 203F. Perhaps my cap is weak? Or is the level drops below the minium mark on the tank. The overflow is not continuous.
This is a new to me bike so I am not familiar with its nature. I have read about the self leveling of the coolant but it seems to me that getting overflow at 203F is a bit too soon isn't it?
post #4 of 11 (permalink) Old 07-01-2010, 08:46 PM
The bikes will spit coolant if the level is too high. There are a lot of threads on what the proper coolant level is. Also be sure the system is purged properly. Again, there are instructions on how to do that too.
If you decide you need a cap drop me a pm with your address and I'll send you one.
post #5 of 11 (permalink) Old 07-02-2010, 12:02 PM Thread Starter
OK CAG
I did the tilt procedure. No gurgling.
I then took the cap off and started the bike up. When the bike got up to temp the coolant started circulating. Give the bike any throttle and the coolant level goes down. Release the throttle and the coolant level slowly creeps back up. Level fluctuates and sometimes the level goes over the top. Hit the gas and the fluid level sucks back down and let off the gas and the whole level rising again and level fluctuating starts over. All with the cap off. It spit out enough that I had to add more distilled water.
I have no idea if any of this is normal as I have only owned one water cooled bike and it never had any spitting up issues.
Thank You
post #6 of 11 (permalink) Old 07-02-2010, 12:25 PM
shoe07's Avatar
when the bike is off and COLD, it should be filled no higher than the MIN line on the overflow tank, otherwise it will vomit until it gets down to that point.
Adding power makes you faster on the straights, while subtracting weight makes you faster everywhere - Colin Chapman
2004 Brutale 750S
shoe07 is offline
post #7 of 11 (permalink) Old 07-02-2010, 01:03 PM Thread Starter
Yep its below that. In fact is at the bottom of the lowest frame tube
post #8 of 11 (permalink) Old 07-02-2010, 01:14 PM
No, that doesn't sound normal. Try the cap first, hopefully that will solve the problem. Sounds like the system is not pressurized. Or, not enough coolant is flowing through the system at idle.
post #9 of 11 (permalink) Old 07-02-2010, 02:12 PM
spr258's Avatar
Just a FYI for who is a good dealer. Call up Pro Italia. Great group of guys if you need OEM parts.
CAG is a person if you need used parts though.
http://www.proitalia.com/
spr258 is offline
post #10 of 11 (permalink) Old 07-03-2010, 07:47 AM
Hmmm, I think CAG is still a person, even if you don't need parts
