unstable at high speeds - MVAgusta.net
post #1 of 16 (permalink) Old 04-24-2010, 10:43 AM Thread Starter
firedancer's Avatar
i hope somebody can help me with this question:
i recently put new tires on my brutale 910 R, Pirelli Diablo Supercoras SP; 120/70 front and 190/55 rear. now before i was using for a long time the 190/50 michelin power pilot. now the bike feels unstable with the front tire at speeds above 200 km/h (it feels the sameway as is the front tire is about to wheely). is this the just the new tires, or can be something wrong with the mouting/balancing of the front tire.
and what are the best solutions?
- lowering the bike in the back to compensate the "higher" tire?
- steering damper?
thanks all for the help.
firedancer is offline
post #2 of 16 (permalink) Old 04-24-2010, 11:03 AM
RikiRix's Avatar
I would consider a full control and check if all has been mounted correctly; or might be just a wrong balancing
SUZUKI RG250 - YAMAHA RD 350 - YAMAHA RD 500 - SUZUKI RG 500 - SUZUKI GSXR 1100 - KAWASAKI ZXR 750 - DUCATI 851S - DUCATI 888 SP4 - MV AGUSTA F4 1000S
RikiRix is offline
post #3 of 16 (permalink) Old 04-25-2010, 03:24 AM
Unhappy Hmm
Check tyre pressures, I have found so many blokes fit a tyre and leave it on silly high pressures, for the road to start at 32/34 psi will do, I used to run the front at 30psi on my Brutale and about 34psi at the back.
post #4 of 16 (permalink) Old 04-25-2010, 04:13 AM
seaeagle46's Avatar
Definately start with a balance re-check. If slightly off you wont feel a thing until you reach the speeds you mentioned.
seaeagle46 is offline
post #5 of 16 (permalink) Old 04-25-2010, 05:52 AM
MvMerito's Avatar
Id check they have been fitted correctly, the correct rotation and balanced- its ball ache but better safe than sorry.
I run exactly the same tyres....
Mine felt as thought the rear was washing under me so iv tried all sorts of pressures to rectify this-
The pressures that work on my F4 750s are 34 front 39 rear- it may sound high but its stable as and im scrubbing right to the edges. The front tyres saved my ass a few times- super sticky rubber
MvMerito is offline
post #6 of 16 (permalink) Old 04-25-2010, 04:47 PM Thread Starter
firedancer's Avatar
thanks all for the advice. i am running exactly the recommended tire pressure by pirelli for this tire and bike; which is 33.3 psi (2.3 bar) front and back. so i will check back with the shop for balancing, as i am planning a track day, but really dont feel safe to hit the high speeds.
post #7 of 16 (permalink) Old 04-25-2010, 05:11 PM
Badger's Avatar
- steering damper?
lowering the back will raise the front making it more unstable, is it not that the tyre profile is now that of a new tyre and you had become accustomed to the slower steering profile of a worn tyre?
My thoughts are this is what you are experiencing
WHEN I READ ABOUT THE PERILS OF DRINKING, I GAVE UP READING!!
Badger is offline
post #8 of 16 (permalink) Old 04-26-2010, 06:32 AM
Actually the opposite: Lowering the back increases rake. This has the effect of slowing the steering...i.e. more "stable", but harder to turn in.
post #9 of 16 (permalink) Old 04-26-2010, 07:54 AM
Arrow Hmm
Getting tooo technical guys
post #10 of 16 (permalink) Old 04-26-2010, 08:21 AM
Badger's Avatar
Me bad, yes it does make it more stable, it had been a long day yesterday and me brain was not working as it should, i meant to put across that it will want to run wide on corners, thanks for the correction mate
Still reckon the tyre profile is a probability
Badger is offline
