1090 Brutale - Notchy gear change - MVAgusta.net
 7Likes
post #1 of 13 (permalink) Old 07-14-2019, 03:37 AM Thread Starter
UKBrutman's Avatar
Whilst I'm relatively new to the bike (2016 B4 ABS model, with 3k on clock) it seems to me that the gear change from 1st - 2nd needs a determined prod and can be a bit clunky at times, nothing too much and maybe just me getting used to the bike. I checked the chain adjustment and that seems fine also looked at clutch, fluid looks clear and at the right level, bite is good and whilst I find the clutch lever a tad heavy, it's probably fine. So interested in any views here.
Previous bikes
Yam FSIE
Kaw KH250
Yam DT175
Suz GSX600
Honda Firestorm
Honda Fireblade
Aprilla RSV Factory
Ducati Multistrada
UKBrutman is offline
post #2 of 13 (permalink) Old 07-14-2019, 05:23 AM
Welcome.
You should probably adjust where the shift lever meets your foot. These transmissions arenít typically clunky.
revhead1957 likes this.
post #3 of 13 (permalink) Old 07-14-2019, 07:47 PM
mvrick's Avatar
thicker engine oil and need a good clean and lube, then fang it in 1st 2nd 3rd, and back down.
All so stop babying MV's, it wasn't the engineers scope, treat it like a race bike. Because all the design and quick release gear box came from a race bike from the past, then trickle down to the public.
I feel the need, the need for corner speed!
Rollen Artwork.
mvrick is offline
post #4 of 13 (permalink) Old 07-15-2019, 12:23 AM
Exclamation ?
MV transmission clunky??????
You're shifting with the clutch.......this isn't a John Deere tractor.....forget the clutch, except for launch and getting into neutral
The problem is YOU, not the transmission
The MVs have the best transmissions of any bike I've ever ridden.....my RD-350 was better but I put probably 100 hours into it, under cutting shift dogs and gears
I have an R1150GS, terrible transmission, with the clutch, clunks EVERY TIME......don't use the clutch, never clunks
mitchy and Deano like this.
post #5 of 13 (permalink) Old 07-15-2019, 07:41 AM
If your 2016 B4 has a slipper clutch, you can feel the early shifts in the lever if the clutch fluid is old.
cruiser likes this.
post #6 of 13 (permalink) Old 07-15-2019, 01:28 PM
GDS968's Avatar
My 1078RR Brutale clunks into 1st every time but rest of the time its smooth if using the clutch!
GDS968 is offline
post #7 of 13 (permalink) Old 07-15-2019, 11:24 PM
MVAgusta.net Sponsor
mitchy's Avatar
Should be smooth as silk like Noel said.
What engine oil are you using?
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is online now
post #8 of 13 (permalink) Old 07-16-2019, 04:20 AM
dansoarr's Avatar
Do you mean it's clunky shifting into 1st from neutral, e.g at traffic lights? If so that's probably just the chain slack being taken up.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is online now
post #9 of 13 (permalink) Old 07-16-2019, 01:52 PM Thread Starter
UKBrutman's Avatar
Thanks for the comments. I'm now thinking this is pilot error, as I get use to the bike!
Previous bikes
Yam FSIE
Kaw KH250
Yam DT175
Suz GSX600
Honda Firestorm
Honda Fireblade
Aprilla RSV Factory
Ducati Multistrada
post #10 of 13 (permalink) Old 07-16-2019, 06:20 PM
Deano's Avatar
That enormous clunk when engaging first is from having the chain too slack. I used to err on the side of too slack out of caution for the hub, but correct tension makes that heaps better. But saying that the engagement isn't as smooth as some. You get used to it. The rest is smooth as silk.
Deano
mitchy likes this.
2009 1078RR Brutale
Deano is offline
