My advice on Lithium Ion batteries & the 40A fuse - Page 2 - MVAgusta.net
 13Likes
post #11 of 40 (permalink) Old 04-02-2019, 02:27 PM
Originally Posted by dipple666 View Post
I had a similar problem with regularly blowing 40 amp fuses.
Turned out to be the ecu. Spiked something in there when I fired her up.
Have you got any more random faults on the bike?
Sent from my SM-G930F using Tapatalk
If you were blowing 40 amp fuses due to an ECU issue, I'd like to know how that could even happen. The circuitry doesn't support it.
'07 Ducati Monster S4Rs ("Slightly" modded...), '07 Ducati Monster 695
post #12 of 40 (permalink) Old 04-02-2019, 02:33 PM
dipple666's Avatar
I'm not sure, but it was constantly doing it. It went to two garages then an mv dealer to nail the cause of the problem.
Mine was on the 750 Senna, Nick Harper also had the same problem and Norwich had to send it away to get the ecu repaired.
dipple666 is offline
post #13 of 40 (permalink) Old 04-02-2019, 02:47 PM
It would have to lock in the start solenoid for that to happen.
post #14 of 40 (permalink) Old 04-02-2019, 04:15 PM
dipple666's Avatar
Who knows. I'm not mechanically or electrically minded but it resolved my issue is all I know
silentservice703 likes this.
post #15 of 40 (permalink) Old 04-03-2019, 10:26 AM
christosc's Avatar
I purchased the MV Branded Lithium battery and fitted it as the original was left on the bike and had to be replaced.
It started life quite powerful enough, but couldn't really tell the difference between it and the lead acid it replaced.
Unfortunately, I left that on the bike a bit longer than intended and it died, but charged it up and it was never the same.
At very first attempt at starting the engine, the dash lights die, and you can see that the dash re-sets itself. The battery eventually becomes stronger and on the second or third attempt, the engine will fire up every time. Since that happened, I have lost the brake light, not sure if this is related, I need to check the fuse no 7 and the connections for that, as I have installed a quick release tail tidy connection (I am mentioning it because I saw that someone else had an issue with the brake lights).
It is quite annoying to have the dash re-setting itself, because all the settings get deleted (trip meters, lap times and traction control).
I wonder if anyone else has the same problem with Lithium batteries.
Thanks for sharing the 40amp fuse issue, this has not occurred to me yet, but it is a good idea to fit one that resets itself, but maybe there is a different problem elsewhere causing it to blow.
Thanks,
Chris
2012 F4 RR Corsacorta
1995 Kawasaki GPz500S
1998 Yamaha R1 (White) Sold
1999 Kawasaki ZX6R Sold
christosc is offline
post #16 of 40 (permalink) Old 04-03-2019, 11:08 AM
The dash reset is a function of low voltage to the ECU during the start sequence. This is one of the indicators that something is amiss with the battery be it lead-acid, lithium, or other....
christosc likes this.
post #17 of 40 (permalink) Old 04-03-2019, 01:38 PM
Edward's Avatar
Seems its kinda like the old comparison between Mac vs PC
Lithium vs lead
That said, there are certainly qualitative differences in materials and manufacturing.
Both have parameters, but most importantly is to make sure your battery has enough voltage for your particular bike and understand overall care must be applied from start to finish with anything associated to motos.
E d w a r d B4910s08
Edward is offline
post #18 of 40 (permalink) Old 04-04-2019, 05:52 AM
Lithium vs lead.
Not really .... (other than price) can you name one advantage of lead over lithium?
Proud owner of a 2015 F4 and a graduate of the school of 'stupid hurts!'
Hawk is offline
post #19 of 40 (permalink) Old 04-04-2019, 06:19 AM
Originally Posted by Hawk View Post
[/I]
Lead will never catch fire.
BSR-1 likes this.
post #20 of 40 (permalink) Old 04-04-2019, 07:18 AM
nigelrb's Avatar
. . . I wonder if anyone else has the same problem with Lithium batteries. . .
I have a lithium in my 2018 Fireblade which is kept on specific 'Optimate' tender when not in use. Not one ounce of problem with starting or dash functions.
2007 MV F4 1000R / 2005 Aprilia RSV1000R Factory / 2005 Aprilia RS50
2004 CBR1000RR Fireblade / 2011 CBR1000RR Fireblade / 2018 CBR1000R Fireblade SP2
1985 Honda VF1000R / 1985 Honda NS400R
nigelrb is offline
