TPS Reset, when? - Page 2 - MVAgusta.net
 2Likes
post #11 of 21 (permalink) Old 11-11-2018, 08:32 AM
The software spoken of is the VDST software for the 5SM ECU. I suspect the TPS does need to be reset to 2.33 v.
post #12 of 21 (permalink) Old 11-11-2018, 09:14 AM Thread Starter
Yes it must be reset. I have 5SM software which i can only read fault codes and measurements with, no tps reset sadly.
The tps atm shows 5.2 degrees and it says throttle is in the midrange and not closed.
I believe that the vdst software is quite expensive, isn't it? Else i'll have it reset at an MV dealership or a mechanic that could do it.
What about the vdst software? What are the costs and is it downloadable/could someone send it over by mail or anything?
Thanks!
Dutchmv is offline
post #13 of 21 (permalink) Old 11-11-2018, 10:00 AM
I have the required software and I could send it to you at your cost. I would need to have it returned to me so that I can work on my bikes.
The program works on an older Microsoft window XP or Vista system.
post #14 of 21 (permalink) Old 11-11-2018, 11:09 AM
The software could be downloaded from a "Dropbox" account or similar...but you need the communication cable to use it.
I also have the tool and would loan it to you, but perhaps there is another forum member nearby who could help??
Like Chuck's software, mine runs on older machines (Windows XP platform). I have an old lap top in my shop just for diag software.
post #15 of 21 (permalink) Old 11-12-2018, 02:59 AM Thread Starter
I have VAG-KKL cables and an ELM327 connector, does one of these do the trick?
If it has to run on XP i have to acheologically dig out my desktop
Thanks!
Dutchmv is offline
post #16 of 21 (permalink) Old 11-12-2018, 03:43 AM
eddypro's Avatar
It runs on windows 8.1 and should run on windows 10, do not try and adjust it manually , Have fun done all this years ago find my posts and there is a lot of them on this topic ,good luck.
cheers Eddy
eddypro is offline
post #17 of 21 (permalink) Old 11-12-2018, 03:49 AM
eddypro's Avatar
vdst software ,you will only be able to reset Tps and adjust Fuel trim ,now fuel trim is important to slightly raise the idle if to low , if the idle is to low you have to muck around with the bleed screws also to raise it . under no circumstances touch any screws on the throttle bodies , DANGER DANGER ,Lol
eddypro is offline
post #18 of 21 (permalink) Old 11-12-2018, 06:57 AM
cheers Eddy
The software I have didn't work on my newer machines. I'm sure later versions would.
The Fuel Trim is only active if you have the "Race" ECU. The standard 5SM will not allow it. That is the one with active o2 sensor. The oxygen sensor controls the fuel trim.
I have no idea if the cables you have are compatible. The "Dongle" in the cable controls what machines the software can talk to. I bought "single brand" only for MV.
post #19 of 21 (permalink) Old 11-12-2018, 10:21 AM
Smoker's Avatar
cheers Eddy
I can confirm that Chuck's software worked on windows 8.1 as well.
esq'z me and silentservice703 like this.
2011 Brutale 1090RR
Smoker is offline
post #20 of 21 (permalink) Old 11-13-2018, 04:43 AM
eddypro's Avatar
By memory i think there is a usb driver update somewhere ,probably on there site ,was a long time ago,No idea on fuel trim on standard ECU .
CHEERS EDDY
eddypro is offline
