How to lock the cam chain so it won't jump teeth! - MVAgusta.net
  • 1 Post By theknurl
post #1 of 9 (permalink) Old 05-21-2018, 09:19 PM Thread Starter
Thumbs up How to lock the cam chain so it won't jump teeth!
Here you go.....
Been doing it like this for 58+ years
You can use string too
gotfolk likes this.
post #2 of 9 (permalink) Old 05-21-2018, 11:49 PM
viljasenmasa's Avatar
Thanks Noel!
Did you change original clam bolts which are holding cam itself? I have read several posts about challenges to loosen those when adjusting valve clearances.
-Varesedreamer-
TVL2016
viljasenmasa is offline
post #3 of 9 (permalink) Old 05-22-2018, 06:15 PM Thread Starter
Originally Posted by viljasenmasa View Post
Thanks Noel!
viljasenmasa;
You don't need to touch those bolts when adjusting the valves
post #4 of 9 (permalink) Old 05-23-2018, 01:35 PM
I mean these bolts which are shown in this thread:
http://www.mvagusta.net/forum/20-mai...er-things.html
Would be difficult to adjust with shims without access to valve cups?
-Varesedreamer-
TVL2016
post #5 of 9 (permalink) Old 05-23-2018, 08:22 PM Thread Starter
This thread is about locking the cam chain in place.......
Nothing else
post #6 of 9 (permalink) Old 03-26-2019, 10:53 AM
Midnicrow's Avatar
I only see the intake cam locked in place. What if you have to shim the intake? Do you lock one at a time? Please expand. I am currently doing this, or trying...
James M.
Midnicrow is offline
post #7 of 9 (permalink) Old 03-26-2019, 12:37 PM
This is locking the chain once timed correctly after shims replaced....prevents the chain from slipping when the tensioner is installed....which can and does happen.
post #8 of 9 (permalink) Old 03-26-2019, 06:10 PM
Robbedoes's Avatar
I looped a thick tie-rap around the chain underneath the ex-cam-shaft and tensioned it with one side under the in-cam-shaft and one side over it. I used a tie-rap because it keeps tension on the chain. The tie-rap rests at the location of the tensioner. *edit* Off course this only goes for tensioner maintenance.
2003 MV Agusta Brutale 750S
Robbedoes is offline
The Following User Says Thank You to Robbedoes For This Useful Post:
post #9 of 9 (permalink) Old 04-04-2019, 08:31 AM
Midnicrow's Avatar
Thank you for the great pics. Yes I can see how this would work also for the valve clearance shim replacement procedure!
James M.
