My key don't open the seat compartment. - Page 2 - MVAgusta.net
 2Likes
post #11 of 16 (permalink) Old 04-25-2018, 06:37 AM
Originally Posted by flyboyaviator View Post
No so far, I need to have a way to grab the cable and tab with locking pliers, and find a find a way to pull with enough force, right now I'm doing it by my self but a friend is coming tomorrow and help, the wife is no able to help.
You should not have to do that. If you are on the left side of the bike, then with your left hand reach under the lock barrel to find the bare cable with your index finger, using your right hand, push down on the center of your tail section near the tail light, now pull the cable with your finger until the latch releases.
post #12 of 16 (permalink) Old 04-25-2018, 06:41 AM
Originally Posted by Huskymoto View Post
I bet the cable outer section has jumped out of the bit under the seat where the latch is.
Mine did this last Saturday and I had to get nasty with a big screwdriver under the cowl whilst twisting it up.
Itís made of crappy plastic that allows the cable outer to jump out the top if adjusted wrong.
I was not amused as I was in the process of removing the junk data tool alarm that had been fitted
This seems a bit extreme. I have had that "crappy plastic" bit break and I was still able to unlock the tail using my method. Even were I not able to do it that way, a simple coat-hanger hook can be slipped in between the heat shield and the tail and the cable can be hooked and pulled to release the latch.
@flyboyaviator: Is your bike Mono or bi - posto?
post #13 of 16 (permalink) Old 04-25-2018, 12:19 PM Thread Starter
flyboyaviator's Avatar
The back cover is open now, I needed to purchase a very small locking pliers, I was able to pull the cable. BTW I was lucky to find the Muzzy fan blades, and replaced then quick, just look at the blades that were replaced.
flyboyaviator is offline
post #14 of 16 (permalink) Old 05-04-2018, 12:39 AM
Talking ?
Attachment 437242
Chuck;
Your chain looks a little tight.......
post #15 of 16 (permalink) Old 05-04-2018, 09:00 AM
Chuck;
You're chain looks a little tight.......
It's only tight on the bottom.....
post #16 of 16 (permalink) Old 05-05-2018, 04:34 AM
MVAgusta.net Sponsor
mitchy's Avatar
Wow,worst blades I have seen.I wish someone would make the Muzzy fan blades.The demand is there.
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is online now
You may post new threads
You may post replies
