Why you need a TAPERED 55mm socket..... - Page 9 - MVAgusta.net
 28Likes
post #81 of 84 (permalink) Old 04-10-2019, 07:14 AM
If you don't know how to measure a taper.......that's your problem
Not sure if that's aimed at me? Yes, I know how to measure a taper, did exactly that on the nut itself as well as the SpeedyMoto socket. The latter didn't have a taper.
Bumpkin is offline
post #82 of 84 (permalink) Old 04-10-2019, 10:49 AM
Yep! The speedy moto socket I obtained last year does not have a taper either.
It knarfs the surface near the root edge of the nut; but I really don't care...
Teeps is offline
post #83 of 84 (permalink) Old 04-12-2019, 09:06 PM Thread Starter
4 MV wheel sockets, 2 are SpeedyMoto , 1 is ProItalia last one unknown manufacturer
THEY'RE ALL TAPERED!
The one in the foreground is even marked MV Agusta
Edward and gotojoe like this.
post #84 of 84 (permalink) Old 06-17-2019, 11:04 AM
Rear wheel F4 and Brutale.
I use tapered sockets ..Wouldn't use a socket that doesn't match the nut properly on principle. You'll mangle the nut and makes a poor show of a classy bike !
I have a tapered aluminium socket to undo; and the best way to undo is a rattle gun without any doubt.
I have a tapered steel socket to retorque....I believe the manual says to have clean threads and apply anti-seize to the first few threads of the axle and none at all to the cone faces of nut or wheel which are meant to grip.
All works well.
Joe
theknurl likes this.
gotojoe is offline
