Steering head bearings - Page 3 - MVAgusta.net
 4Likes
post #21 of 29 (permalink) Old 04-04-2018, 11:14 AM
Well...I stand corrected, having never had to look at my MV's steering heads. Caged balls...nice. Must be another reason why an MV costs more than a Honda.
In 40+ years of working on Jap bikes I have never seen caged balls in the steering head. You use a heavy grease to hold the balls in place while assembling.
Thanks for educating me Noel.
Do Ducatis and other Euro bikes use caged balls, too? I know they didn't back in the 70's.
Honda has had caged bearings for a long time as well, at least since the 80's. My 81 CB900F had roller bearings, 954RR had caged balls along with all other sport models. The only time I've seen loose bearings in a steering head was on an episode of the Reassembler with James May and an old Honda monkey bike.
pittmeister is offline
post #22 of 29 (permalink) Old 04-04-2018, 01:54 PM
Well...there you have it....only Hondas with ball bearings in the steering that I've worked on since dealership days in the 70's were vintage bikes.
The CB900F tapered rollers were in response to the prior SOHC 750's decel head shake.
Learning every day.
No caged balls on Suzukis....
post #23 of 29 (permalink) Old 04-06-2018, 10:01 PM Thread Starter
cus
cus's Avatar
Update, managed to get tapered roller bearings locally. Thanks heaps for the assistance Mitchy. They are now fitted. Put the stem in the oven on 180 for five minutes and hit the end of it with a rubber mallet and the old ones flew across the kitchen floor. Did the same for the install and put the races in the freezer for half hour as well and they pushed in by hand.
cus is offline
post #24 of 29 (permalink) Old 04-08-2018, 03:08 AM
MVAgusta.net Sponsor
mitchy's Avatar
Good to see you are using the kitchen as a workshop Mark.Was the wife out shopping.
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is online now
post #25 of 29 (permalink) Old 04-08-2018, 04:53 AM
Gero HH's Avatar
The steering head bearings on my TVL are defective. Didn't make it through the MOT. Now I have 4 weeks to replace them. But unfortunately MV cannot deliver. Does anyone know where I can get these bearings elsewhere in Europe?
he OEM Part No. is : 8000B4784
Gero
______________________
2016 Turismo Veloce 800 Lusso
Gero HH is offline
post #26 of 29 (permalink) Old 04-08-2018, 05:29 AM Thread Starter
cus
cus's Avatar
Havenít got one of those anymore hence all the bikes in the house
mitchy and mitchy like this.
cus is offline
post #27 of 29 (permalink) Old 04-08-2018, 05:34 AM Thread Starter
cus
cus's Avatar
They are probably just loose, can you tighten them up or even regrease and tighten up just to get through
theknurl and theknurl like this.
cus is offline
post #28 of 29 (permalink) Old 04-09-2018, 11:42 AM
MarcSilverTriple's Avatar
This is the same bearing as all 3 cylinder range (F3, B3, Rivale, Stradale, TV). I checked and it doesn't seem to be the same on the F4/B4 series (as per the references).
Same statement. The bearings may be just loose and tighten them may be enough to temporarily solve the issue. Otherwise, any proper mechanic guy should be able to find the proper bearings for replacement without even having the MV reference: those all ball bearings should be fairly simple to source as you just need the internal diameter, the external diameter and the height of the bearing to get a replacement bearing.
And anyone changed them on a F3, B3, Rivale or Stradale may be able to pull another valid reference than the one from MV
Marc,
Turismo Veloce in France
MarcSilverTriple is online now
post #29 of 29 (permalink) Old 05-12-2018, 10:55 PM
The correct number for the tapered roller bearing was already listed 32907 JR-2
But the size was incorrect, it's 35 x 55 x 14 not 15
