Massive Calamity Averted - Page 2 - MVAgusta.net
 11Likes
post #11 of 58 (permalink) Old 02-17-2018, 10:52 AM
Originally Posted by pittmeister View Post
Always fortunate to have a quick and easy fix.
Do you know if it was tightened using the nut when it was first installed? I wonder if it's just poor design that there are stresses that build up in the spot welds or if tightening using the hex contributes. I've always understood that the nut is only for removal, but with a description like "17mm Hex Nut Allows Easy-On, Easy Wrench-Off" I can see it being misinterpreted too easily.
Poor build quality. Materials and welding technique created a very weak spot that engine oil pressure can break.
Just a crappy oil filter anyway. Read the reviews on filtration properties in the independent testing. Buy something better.
post #12 of 58 (permalink) Old 02-18-2018, 05:45 AM Thread Starter
Given the confined location for getting my hand around the filter to tighten it I'm guessing that I did use a socket on it to tighten it. Given that I know from experience that spin filters can be a bastard to remove to service I do not tighten them very much at all. Also as MVs' have a locking band there is no need to tighten them very tight.
ogrilp400 is offline
post #13 of 58 (permalink) Old 02-18-2018, 05:46 AM Thread Starter
Thanks guys for all the information and now that it has all come out I do recall the threads against using them.
I will now be fitting an other brand of filter, a Purolator if I can find one here in Gippsland Victoria, Australia.
post #14 of 58 (permalink) Old 02-18-2018, 07:57 AM
Use a proprietary filter wrench or pliers to remove a filter.
Don clean sticky rubber gloves to get a grip on the installation of a new filter...or use said filter pliers with caution against crushing.
You need to tighten the filter to spec in order to prevent leakage at pressure.
post #15 of 58 (permalink) Old 02-18-2018, 09:26 AM
Teeps's Avatar
And, make sure the old oring is not stuck on the block.
2016 Turismo Veloce 800
Teeps is offline
The Following 2 Users Say Thank You to Teeps For This Useful Post:
post #16 of 58 (permalink) Old 02-18-2018, 11:48 AM
Ian SAVS's Avatar
Send a message via Skype™ to Ian SAVS
All that oil on that tire? Lucky man. Im surprised you were fortunate enough to stay rubber side down.
What we've got here, is failure to communicate.
Ian SAVS is offline
post #17 of 58 (permalink) Old 02-18-2018, 07:40 PM
ddmv's Avatar
Wow lucky man indeed.
ddmv is offline
post #18 of 58 (permalink) Old 02-20-2018, 07:55 PM
Farshore's Avatar
Had the same thing happen but caught it just in time. Save the broken filter and send it and any invoices to K&N, they paid for my oil change, reimbursed and replacement filters ( not K&N obviously) theyll also cover damage Im told.
09 F4 312 1000
Farshore is offline
post #19 of 58 (permalink) Old 02-20-2018, 08:13 PM
I suspect they had a few law suits.....
post #20 of 58 (permalink) Old 02-20-2018, 08:36 PM
Farshore's Avatar
Its a standing guarantee on all their products is my understanding like air filters.
https://www.knfilters.com/mobile/warranty.htm
09 F4 312 1000
Farshore is offline
