MV Tools, Shop Supplies, Part Sources and Interchangeability. - MVAgusta.net
 5Likes
  • 4 Post By theknurl
  • 1 Post By andrew fotheringham
post #1 of 7 (permalink) Old 07-03-2017, 09:01 PM Thread Starter
Thumbs up MV Tools, Shop Supplies, Part Sources and Interchangeability.
Here it is copy it and print it
Tools
the following is a list of tools to let you service your MV....some of the tools will be rarely used so you might want to go in on them with your fellow MV riders
>a real rear stand to replace the Factory POS
>wheel nut socket 55mm tapered w/ 1/2" drive all the way through off eBay
>1/2 drive torque wrench 250 Nm or 200 lbft capacity
>1/2 drive 10" extension
>1/2 drive 26mm socket
>1/2 drive 27mm socket
>1/2 drive 28mm socket (2nd Gen front axle)
>1/2 drive 32mm socket
>3/8 drive torque wrench 10-50 Nm
>117mm C-spanner for adjusting chain
>steering stem wrench MV tool #800091645 or one off eBay
>bearing lock ring tool MV tool #800092857 or one off eBay
>seal driver for both 49mm&50mm forks from MotionPro #08-0171
>wrenches to fit 41mm front axle and nut
>3/8 drive ratchet and extensions
>3/8 drive sockets;8,10,12,14,17,20mm, 4,5,6,8,10 Allen sockets
>3/8 drive impact screwdriver, I use a SnapOn PIT-120 eBay
>cable luber
>oil filter wrench for Purolator PL 14612 old yellowish, Vector #17009
>oil filter wrench for new blue Purolator PL 14612, Hopkins 10605 Flotool Super Graphite Filter
Wrench #5...Amazon, free shipping
>pipe spring tool, aka headlight adjusting tool
>chain breaker/riveting tool
>Clic-R pliers eBay
>#1,#2 Phillips screw drivers
>DMM digital multimeter
>5/8 spark plug wrench
>a set of ball end metric Allen wrenches
>8,9,10,11,12mm combination wrenches
>12mm SnapOn Flex head combination wrench for the exhaust clamp nuts
>14mm drop box wrench for the shock toggle pivot bolt
>36mm wrench or slotted socket to remove fuel tank sending unit
>a set of feeler gauges for the valves
>metric micrometer to measure valve shims
>external snap ring pliers with 0.090" tips for the brake backing plate snap ring
>small wooden or plastic wedge for opening the gap in the swing arm to easily get the hub out
>ride height tool available from Chris (X81)
>VDSTS tool from TechnoResearch to set the TPS
>free software from Adam (merc07) top of the Performance Section
....and for you Antipodeans a baseball bat as recommended by eddypro to change your rear shock.....
"hang on Noel, you forgot to include my baseball bat tool,that i used to change my rear shock,Lol"
see Eddy I remembered
Shop Supplies
>LocTite #242,#271
>high temp RTV silicone seal
>dielectric grease
>Never-Seez or Coppa-Slip(smallest container you can get)
>CV joint EP grease
>waterproof grease
>a can of Kroil, super penetrative solvent (or a 50/50 mix of acetone and ATF)
>4mm,5mm,6mm Wellnuts
>4mm,5mm rivet nuts(you can install them with pop rivet pliers and a headless bolt)
>zip ties
>fuel tank and fuel line O-rings McMaster Carr part numbers
fuel tank 9452K197
fuel line 9262K141
>DOT 4 brake fluid
>cable luber for MVs with cable clutches
>chain lube
>oil filters(Purolator PL-14612) (1st Gen bikes)the old yellow filters are 76.5mm long
the new blue filters are 76mm long and use a different wrench (thanks to the new NAZI owners of Purolator)
>fuel filters(WIX part #33012)
>fuel line pressurized in tank, 5/16" spec SAE J30R10
>a spare 3810-2RS bearing (1st Gen)
>a spare 6810-2RS bearing (2nd Gen)
>talcum powder for finding leaks, powdering Joe's ass or making your rubber gloves easy to get off and on
>Beer or wine for when you're done working on your bike (Thanks Andrew!)
there you go.
Interchangeable Parts:
>MV starter solenoid = Yamaha 4SV-81940-12 ~ $6.00 on eBay free shipping
>MV fuel pump plate quick change metal fittings Triumph #T1241477
>MV John Guest fuel rail fittings....Dorman 800-185
>MV shift lever torsion spring = Yamaha 90508-291A8 ~$3.81+shipping
>MV TPS sensor PF 3C at the Harley Davidson dealer~$40
>MV 2 wire water temperature sensor Jaeger #401976
>MV oil pressure sending unit GM#93190643
>MV latch relay Hella #H41388131
>MV headlight and fan relays 4 pin #233454 12v
>MV turn indicator bulbs OSRAM #64415
>MV turn indicator connectors ITT Cannon MiniSureSeal male #120-8552-100 female #120-8551-100
>MV 1.6M ECU REPAIR
http://www.carmousa.com/
MV 1.6M ECU get one from a Ducati and use your chip
>MV CCT same as Kawasaki KX250F, Husqvarna #8000A5199 these are automatic
> Manual CCT Tokyo Mods for a Kawi KX250F
>LEDs for the dash T3 wedge & T5 wedge
>Oil filter Purolator PL-14612, if it's too long Mobil M-108 (Gen 1)
>Fuel filter WIX #33012
>McMaster-Carr part numbers
Fuel pump plate O-rings #9452K197
Quick disconnect O-rings #9262K141
M4 alloy rivnuts for injector covers #94020A371
>Tapered roller bearings for the steering head 32907 JR2
>Bearings, PM me
>Iridium spark plugs NGK CR-9EIX eBay
>Champion stick coils replacements plug & play
https://www.mvagusta.net/forum/20-ma...plug-play.html
>Beru stick coils ZS 378 for 910,989,990,1078,R312 and RR312
http://www.mvagusta.net/forum/20-mai...eru-zs378.html
Beru.FederalMogel.com
bar code # 4014427122135
trade # 0040104002
>750 fuel injector IWP-048 OR IWP-076 both 215cc/min remove air jacket
>1st Gen key blank Ilco KW14
>1st Gen 4 pad replacement brake pads, last 4 times as long as Brembos, EBC FA 322-4/HH
>1st Gen ND alternator repair http://www.mvagusta.net/forum/20-mai...-resource.html thanks to pittmeister
>John Guest fuel line connector replacement part Dorman #800-185
>4 pin alternator plugs www.cycleterminal.com you want set YC2504 thanks to gotfolk
>REPLACEMENT KEYS....even chipped ones....one day turn around
MOTORCYCLE SCOOTER KEY VESPA PIAGGIO HONDA KAWASAKI YAMAHA HARLEY BMW DUCATI TRANSPONDER CHIP
Jim Hamilton
207-230-4667
Plug wiring codes:
>02 sensor #1 black #2 gray #3&4 white
>Fuel pump plug #1 red #2 black #3 orange #4 white..... harness #1green/blk #2blue #3purple/w #4purple
>starter solenoid plug back, latch up L>R top row black, blue, plug bottom row red, white, gray
harness plug latch up top row plug, red, blue bottom row white, black, green/red
SPU for loan, working blue back #8000A9615 PM Chris @ chandler325i
SPU repair http://www.mvagusta.net/forum/20-mai...u-service.html
>Triple Service Bulletins
http://net.mvagusta.it/scheda/dettaglio/98/131?lang=en
The Following 4 Users Say Thank You to theknurl For This Useful Post:
post #2 of 7 (permalink) Old 07-04-2017, 07:57 AM
Thank you for going thru the trouble to do this. As a new MV owner it's appreciated. Now I wish I could find a decent Haines type manual for the 750 F4.
rompus is offline
post #3 of 7 (permalink) Old 07-04-2017, 08:07 AM
@rompus: Why would you want some universal manual? The manuals are available for no charge through Donsy.....
post #4 of 7 (permalink) Old 07-05-2017, 05:35 PM
andrew fotheringham's Avatar
Noel, you forgot to add a few cold beers for when you're all done and proud.
theknurl likes this.
andrew fotheringham is offline
post #5 of 7 (permalink) Old 07-05-2017, 07:19 PM Thread Starter
Thumbs up !
Corrected
post #6 of 7 (permalink) Old 03-26-2018, 08:04 AM
@theknurl: Noel, thank-you, AGAIN, for this thread. I just ordered a bunch of o-rings today.
post #7 of 7 (permalink) Old 03-26-2018, 10:42 AM
Teeps's Avatar
Ditto.
Also for 2016 TV riders add a 28mm socket (front axle nut.)
2016 Turismo Veloce 800
Teeps is online now
