125 TR Clutch - MVAgusta.net
post #1 of 3 (permalink) Old 04-20-2014, 02:33 AM Thread Starter
125 TR Clutch
Hello,
Would anyone know where I can find new clutch plates for my 1954 125TR? Preferably in Europe.
Thanks!
By the way, what oil do you use? I was told 20W50...
LittleRedDevil is offline
post #2 of 3 (permalink) Old 06-14-2014, 11:40 PM
surflex.
http://www.surflexclutches.com/Surfl...eterane%29.pdf
way too many small italian bikes to list!
motorusti is offline
post #3 of 3 (permalink) Old 06-23-2014, 06:50 AM
Sheriffof0's Avatar
@LittleRedDevil
Some helpful facts for your files:
MV Agusta TR 125cc 1955
▶Tank holds 12 litres
▶123.6 cc
▶Sump holds 1.3 litres of 20/50 or 15/40 mineral oil
▶Consumption is 1l per 50km
▶Wheel size 2 and quarter" x 18"
▶Tyre size 2 and 3 quarter" x 18"
▶Inflate front 19.1psi; rear 25psi
▶1st gear > 28kph
▶2nd gear > 48kph
▶3rd gear > 66kph
▶4th gear > 80kph
▶Electrics 6v 30w headlight; 15w brakelight; 5w taillight
▶54 mm bore piston
▶Tappet clearance 0.03-0.10mm
▶Intake valve opens 30* before TDC
▶Intake valve closes 68* after TDC
▶Exhaust valve opens 70* before TDC
▶Exhaust valve closes 26* after TDC
▶Spark gap 0.6-0.7mm
▶Plug NGK B8ES
▶Points gap 0.07mm
▶Ignition advance 38*
▶Compression ratio 8.5:1
▶6bhp at 6000 rpm
▶Carburettor DellOrto MA16b
▶Weight 102 Kg
▶Front & Rear brake 123.5mm
Sheriffof0 is offline
