1976 MV125 S drain plug - MVAgusta.net
post #1 of 2 (permalink) Old 05-14-2011, 03:09 AM Thread Starter
GTW36's Avatar
Hello,
Yesterday i drained the oil from my 125S.
I had great difficulties to undo the "plastic" drain. The six flats socket wrench i used was jumping over the nut edges. I fixed the problem by machining the front face of the socket to make it more sharp.
Two questions : what kind of plug gasket do you fit ? Mine was fitted with a sort of "flat O-ring". I dont know what kind of gasket material is adapted wit this soft plastic plug ?
Is there some alternative fitment to this weird soft plastic plug ?
Regards
Dominique
GTW36 is offline
post #2 of 2 (permalink) Old 05-14-2011, 04:46 AM
emmevi125s's Avatar
hi Dominique
At a guess, the drain plug/oil filter was a disposable part which was 'disposed of' at each oil change, Unfortunately, they are no longer available. I have a feeking quite a few MVs have a similar plastic sump plug.
My solution was to get a brass plug made onto which the filter from the plastic plug was attached.
emmevi125s is offline
