150 RS fork oil question - MVAgusta.net
post #1 of 4 (permalink) Old 05-05-2011, 12:11 PM Thread Starter
Can anyone tell me what is the capacity and type of fork oil
used in a 150RS?
I was going to use Bel-Ray 20 wt, same as I use in my Matrella, but
I still need to know how much.
Thanks,
George Ellis
ellis is offline
post #2 of 4 (permalink) Old 05-07-2011, 06:25 PM
Dorian's Avatar
Hi George.
MV never listed a quantity or weight for the fork oil on the old singles.
From experience around 125cc seems to work OK. You might fins 20 weight a bit too stiff, but then again it all depends on your riding style etc. I use 10 weight on most of mine and it seems to work OK, however if the forks are a bit worn a slightly thicker oil might be better. A bit of experimentation might be in order!
Cheers.
Dorian.
Dorian is offline
post #3 of 4 (permalink) Old 05-07-2011, 08:14 PM Thread Starter
Dorian,
Thanks for the fork oil info.
The forks are the ones that I got from MV Spares, they were in very good shape. I only had to clean them before new seals.
I will try the 10 weight oil first.
Thanks again,
George Ellis
ellis is offline
post #4 of 4 (permalink) Old 05-08-2011, 11:00 AM
Dorian's Avatar
No worries George.
Woops, i had forgotten that i sold you some forks, must be getting old!
Dorian.
Dorian is offline
