post #1 of 6 (permalink) Old 03-06-2019, 03:22 PM Thread Starter
175 manual project
I'm rebuilding a MV 175 basket case- in the process of trying to figure out what goes where I'm making drawings to supplement the poor parts manual and nonexistent service manual- I'll attach a couple of drawing of the transmission assembly. I'm having some trouble with the shifter mechanism- will send drawings with my questions later. Eventually, I'd like to get small batches of some parts made- will start another topic to discuss them.
Rick
chip is offline
post #2 of 6 (permalink) Old 03-06-2019, 03:40 PM
Nice drawings you have made there .... I see primary drive, clutch, kick starter, transmission shafts.....where is the shifter?
post #3 of 6 (permalink) Old 03-06-2019, 04:32 PM Thread Starter
This is the gear selector mechanism- there's a line stamped on the 3d tooth from the top of the gear quadrant and a notch ground into the spur gear on the drum- it's in the root between 2 teeth. I thought the 2 marks should line up, but they won't assemble into the crankcase when they're aligned- I need to do some more measuring/testing to see what the problem is- maybe someone knows how or even if the 2 marks align?
Rick
chip is offline
post #4 of 6 (permalink) Old 03-06-2019, 08:06 PM
I suspect the marks are supposed to align, but perhaps with the transmission gears engaged in a specific position? From the marks on the gears I would guess that is neutral.
post #5 of 6 (permalink) Old 03-14-2019, 05:05 AM
Mondello175's Avatar
Yes, the marks should align. I also struggled to align them, then found I was missing a gear but it easy to correct by removing the selector plate.
Which engine is it?
I rebuilt my CS175 and have a lot of photos of the internals if that helps.
Mondello175 is offline
post #6 of 6 (permalink) Old 06-28-2019, 02:44 AM
HI chip if you look on E Bay there is a spares catalogue showing exploded drawings , its for the 175 CST-L etc , hope this helps
264378636942 this is the reference number on E Bay
dogeardjap1926 is offline
