350 ipotesi valve adjustment - MVAgusta.net
post #1 of 3 (permalink) Old 11-06-2018, 01:31 PM Thread Starter
gunnar's Avatar
Can’t find specs for this anywhere. Anyone know what this should be?
'70 Triumph T100R Flat Track
'74 350 Elettronica
'64 Tevere Motocarro
'76 350 Ipotesi
'68 Vespa Super
'64 Vespa Cushman 150
'73 Honda Z50
gunnar is offline
post #2 of 3 (permalink) Old 11-06-2018, 01:53 PM
skorpion's Avatar
Extract from owners manual
VALVE CLEARANCE
Every 3000 miles, or if the timing system is very noisy, check the clearance between valve and rocker arms.
The adjustment is carried out in a cold engine, the piston top dead center, with valves closed and precisely at the end of the compression phase.
Step 1 Unscrew the nut (1) and tighten or loosen with a wrench, adjusting
screws (2).
Step 2 The prescribed clearance shall be maintained.
Intake valve mm 0.05 0.002 in
Exhaust valve mm 0.10 0.004 in
John B
Auckland NZ
MV Agusta 350 S Ipotesi
Aermachhi 350 SS
Aprilia Shiver 900
skorpion is offline
post #3 of 3 (permalink) Old 11-06-2018, 02:04 PM Thread Starter
gunnar's Avatar
Thank you!
'74 350 Elettronica
'76 350 Ipotesi
'68 Vespa Super
'73 Honda Z50
gunnar is offline
