125 Battery box question. - MVAgusta.net
post #1 of 2 (permalink) Old 12-03-2017, 12:17 PM Thread Starter
Meccanicopronto's Avatar
Hi all, just repainting the central battery box on the 125 TRA. Thing is, it's never had a battery strap since I got it. It has a plate inside with the two welded/captive nuts at the bottom. Question is was the bottom strap clip part of this plate or part of the door hinge pin. Never been able to find a photo on the net. If anyone has a photo of a fairly original setup I'd be very grateful as I can make a replacement.
Meccanicopronto is offline
post #2 of 2 (permalink) Old 12-15-2017, 01:26 PM Thread Starter
Someone must know something???
Ok, so this might be easier if I show you what I've got. Here are some pics before I paint. Was there a small tray to support the battery at the bottom? Perhaps a thick rubber? Thing is it fits ok as it is but I can't see MV just having it supported on the bottom corners. The clip for the strap is at the top and my best guess is that the bottom clip is part of the hinge pin. Grateful for any and all ideas, ta.
