CS175 burning oil. Thoughts please everyone? - MVAgusta.net
 2Likes
  • 2 Post By GTW36
  • 2 Post By Mondello175
post #1 of 6 (permalink) Old 11-15-2017, 01:54 PM Thread Starter
Mondello175's Avatar
I've now removed the cylinder head from my CS57 to investigate where the blue smoke is coming from. It got so bad that after a fairly long downhill I stopped at a roundabout and got overtaken by a blue cloud - embarrassing!
I've only had the bike a few months and it's the first look inside for me.
Anyway, I have my own thoughts on the problem but would like to know what others think, based on the photos.
So, thoughts please everyone?
And suggestions on how to resolve.
Mondello175 is offline
post #2 of 6 (permalink) Old 11-15-2017, 02:01 PM
GTW36's Avatar
Look at the exhaust valve guide, an excessive play between valve stem and valve guide will cause a "nice blue cloud of smoke".
You can look also the rings gap and if there is a step at the upper part of the bore (sign of a worn cylinder bore.
Mondello175 and Mondello175 like this.
GTW36 is offline
post #3 of 6 (permalink) Old 11-17-2017, 01:55 AM
Running downhill with closed throttle creates a vacuum in your combustion chambers.
This will make the oil sucked into your combustion chaimber if:
a] Poor valve seals.
b] Worn or broken piston rings.
c] Piston rings stuck in their grooves.
d] Excessive wear on the cilinder.
You could try to put some fluid on top of the piston and see if it leaks away for a quick check. But the proper way would be to measure wear with a micrometer and compare it to the factory specification.
I think you have to pull the cilinders for a proper diagnose!
XJ750SECA --> RD350LC YPVS --> CBX1000F --> CBX550F2 --> RD350RR --> RD500YPVS --> FZ400R --> F3675 --> 899PANIGALE --> 959Panigale
RCEE is offline
post #4 of 6 (permalink) Old 11-19-2017, 04:14 PM Thread Starter
and here's what I think
Thanks to GTW36 and RCEE for your suggestions.
I'm fairly sure the root cause is oil leakage down the valve guides but not because they are excessively worn - see my blog for more details and the solution I intend to implement.
https://cyclemasterron.wordpress.com...ce-of-smoking/
post #5 of 6 (permalink) Old 12-06-2017, 07:22 PM
Don't forget you can get reusable copper head gaskets from Copper Gaskets Unlimited. They are my pattern but Ronnie will sell you one. Make sure you get the "CSS" one with the larger stud holes. Hope it helps!
1954 MV 175 CSS Super Sport
1957 MV 175 CS Modello Sport
1967 Motobi 125 Sport
1974 Ducati 750 GT
Left Coast USA
hulagun is offline
post #6 of 6 (permalink) Old 12-07-2017, 06:00 AM
Decel smoke.....valve guide. Your photos confirm. Combustion chamber and spark plug look nice and clean.
